- Loopysue
- 9,987
- Member, ProFantasy
- 9,864
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
First Ferraris Style Map
Scaling Bitmap Fills
A Quick B&W Village
B&W City on River
Commission WIP!
No Flowers Petals with Flowers using Japanese Temples
It should be possible to repair the existing map one of two ways, in no particular order:
- By renaming the bad symbols in the Symbol Manager, OKing that, saving the file, reopening it, and then clicking the good symbols from the new FSC to load them into the map. Then you can replace the renamed malfunctioning symbols with the new ones.
- Alternatively, and if that sounds a bit complicated and you only have a handful of them in your map anyway, you could delete the bad symbols from the Symbol Manager, save and reopen the file, and then paste fresh from the new FSC
Kasuga - Japanese Temple Complex
If you click the fill style box and open the Fill Style Properties dialog, then pick the Bitmap Files tab and select one of the troublesome fills you should see that it is Scaled and that it has a set Width and Height.
(Sorry about the jiggly red lines - my hand is a bit shaky, as I have Covid right now and I'm not terribly coordinated at the moment)
To make the fill appear larger in the map and reduce that pattern a bit you could increase the dimensions in those boxes. As with all things, though, there is a limit to how far you can push it like that before you get pixilation issues.
It's the same scale in CC3 as it is in your export. The appearance may differ a lot, though, depending on the size of your export.
