- Loopysue
- 9,987
- Member, ProFantasy
- 9,864
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Wet medley and a city!
Token Treasury symbols for commercial use
Hi Gathgar :)
The EULA is here if you want to refer to it at any point in the conversation: https://www.profantasy.com/service/license.asp
While I am employed by Profantasy I work on the art side of things more than anything, so I can't really give you a definitive answer. For that you will have to contact Profantasy directly using the email link "Licensing questions" on the contact page here: https://www.profantasy.com/service/default.asp
Service is good, so you should get an answer before too long.
change size of map
You can use the Resize Drawing Area option in the File menu to adjust the size.
When the dialog opens it will show you the current size of the map in map units. Edit those numbers to change the size of the map. The existing drawing will remain as it was in the bottom left corner of the new drawing area, but it's easy enough to move it if you wanted more space all around.
The Creepy Crypt project
Made a custom Wagner VII projection, but is there already a template available?
There are several ready made projections available in the March issue of the 2014 Cartographer's Annual if you have it (you get to them by opening a new overland map and selecting "Pick a pre-defined template"), but none of them are Wagner VII.
Well done - a beautiful map :)
Ferraris Style; Ramparts Not Working
When I opened your map I saw the pits as you described them
I copied the pitted polygon to the WATER sheet by right clicking the hourglass and using the "Copy to sheet" option to copy it to the WATER sheet.
And got this result.
All it does is add a backing to the overlying polygon to separate it from the underlying one. Normally you have to then go and change the copy to be a solid colour that isn't in the texture, but it seems to work fine without that.
June Free symbols?
[WIP] Chisinau
