- Loopysue
- 9,987
- Member, ProFantasy
- 9,864
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
The Creepy Crypt project
Making hand drawn seamless tiles
Heraldry Symbols
@Quayuazue How very inventive of you! :)
The trees look ok, but it shouldn't take too long to trace the shape if you can't find one you like by googling it
If you find a perfect bitmap example of a reasonable size that is black and white, and then if you remove the white from the image in an image editor and import the resulting transparent png, you can either use that as your symbol, or you can use TRACED on it to create your own vector one.
Community Atlas: Embra - Hilly Places
Community Atlas - Doriant - Galahais - The Morstarik
It's better, but... have you got some kind of blur on the text sheet? If you have, switch it off and see if that makes things clearer. The very tiny imperfections seen on screen when no blur is used usually vanish on export if you use about 20-30% antialiasing.
Also, some fonts don't really work when they are emboldened because the characters touch each other, as you can see between the 'a' and the 'l' of 'Caldach'. Consider using normal instead of bold, or a different font that doesn't have that particular issue.
CA143 Asian Town - Eliminating TA & purple box issues
Wet medley and a city!
Live Mapping: Modern Atlas
