9,987
Member, ProFantasy
9,864
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Missing buttons
    First rule of installing any piece of PF software is - don't start manually moving anything around. I am aware that some bad advice was recently given on the FB Group page about moving things around, but this is a recipe for disaster. Please don't do that.
    The installers put things in the right place, however, not all Symbol Sets have the same structure, so you can't compare them against one another like that.
    Carry on installing your add ons (it doesn't actually matter which order you do them in as long as they all come after CC3 and you do a final reinstall of the most recent CC3 Update at the end of the process).
    SS1 and SS2 don't have buttons.
    ScottA
  • Tracing an edge
    No. It was meant as a solution to help you produce a shape to draw your border areas, which I noticed were lines of set width along the coast. You can't draw lines that thick and that wiggly without those artefacts you mentioned. The solution is to draw them as polygons with lines of zero width, but around the outline of the intended line. That would require a guide shape to do by eye, so the two glows act like a template - a drawing guide.
    However, it is possible that I have mistaken your intent. I was working on what I could see in your shot.
  • The Creepy Crypt project
    Fungus is on the list Julian.
    Thank you! I think it's probably just that a change is good every now and then.
    I'm not doing an entire dungeon style - just the crypt aspect for now.
  • Filter DLL Files Missing
    I have just downloaded and opened the first of those two files.
    I can't see any problems with it on my PC. What did you mean when you said the sheets weren't working?
    Here is a small part of the map as a screen shot. Those red Xs are there because their are images you have imported that don't exist on my system, but that's the way CC3 shows the space where artwork is missing.
  • Problem with doors
    Hi Dave :)
    Can you hide all the sheets except for the WALLS sheet, and then use List from the Info menu on the walls?
    That will give you a blue window listing all the attributes of the wall(s) you picked, which will show you which layer they are on.
    Cutting symbols usually have a red line with a tiny cross at either end - visible in the symbol catalogue pane.
    Layers do not control the order of appearance, which is why the list of layers is alphabetical.
    Sue
    Octorilla
    Hi Octorilla :)
    This is quite an old thread, so my approach to solving your problem may not seem to relate very well to the things helpers used to say about doors and walls higher up the thread, because the app has come a long way in all those years.
    First, can I ask how you drew the walls?
    Door and window symbols are usually cutting symbols these days (though you can still find those which don't cut). They cut, but they only work on lines drawn on the WALLS sheet and layer to prevent them from cutting anything else (like the floor, or any other polygon that just happens to be there). The special wall and room drawing tools found at the top of the left toolbars will automatically place walls on the correct sheet and layer so they will be cut by the cutting door and wall symbols, but if you use any of the primitive drawing tools on the right toolbar it is a matter of sheer luck if they end up on the correct sheet and layer.
    No problem if that is what has happened. You can move the walls to the correct sheet and layer using the Change Properties tool on the left toolbar.
    Octorilla
  • Searching for symbols for WW2 and modern military vehicles, artillery etc.
    I think you've done a pretty good job :)
    Lizzy_Maracuja
    All this wonderful creativity! :D
    Lizzy_Maracuja
    Tricky.
    I don't suppose there are any vehicle plans that are definitely in the public domain that you could trace?
    Or if you had a model that you could photograph from above, you could trace the photo without worrying about copyright.
    Lizzy_Maracuja
  • Panzer sample thread
    Oh yes - that definitely works! :D
    Lillhans
