- Loopysue
- 9,990
- Member, ProFantasy
- 9,866
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Sepia Study
Fill Style Import - How to?
Make a folder called User in the Bitmaps folder here:
C:\ProgramData\Profantasy\CC3Plus\Bitmaps
Then put your png fill style in that folder and import them using Import bitmap fill styles in the Tools menu. You should then be able to pick them in the Fill Style Properties dialog and use them as polygon fills.
CA 2019 and Wilbur
Some Traveller sub-sector maps I have done
New Symbol Not Showing in CC3+
Just checking that you aren't importing the image as an image, and not a symbol.
Check that you haven't called the one that's missing exactly the same name as one of the existing symbols.
Remy just suggested - double check that it really is a png image, and that the length of the filename doesn't exceed 32 characters.
Battlemap House of a retired adventurer.
Size of Sue's parchment bitmap
Remy is right if you want the parchment to look the right shape on screen, or you could rotate it 90 degrees to make it a better shape and reduce the amount of distortion before you scale it.
However, there is an alternative.
if you are working towards a bitmap export as the final map, and if the technical map border is in the right place (the technical map border is usually a set of green lines on the map border layer that denote the edge of the export), it doesn't matter how far outside the image sticks because it will be cropped out of the export providing you have the "Restrict image to map border" checkbox in the Options in Save as... checked (see below). If you set it up like that you could have the parchment stuck out all over the place and it wouldn't matter.
issue exporting
That's what I meant - yes. I think most of the grid is disappearing in the export where the lines are only one pixel wide, leaving only that one line visible where I thought there was a glitch in the render.
In the attached map I have adjusted the grid for you (using Change Properties) to give it a line width of 0.02, and played a little with the glow on that sheet for you. You may need to change it again to suit your style - what I did is just a demonstration of what I was talking about earlier.
Were you aware that you have all the relatively low and flat symbols like the skeletons on the SYMBOLS sheet, and that this sheet is casting disproportionately long shadows over the ground area? I see you have the trees on a SYMBOLS HIGH sheet, so there wouldn't be too much harm in reducing the size of the shadow on the SYMBOLS sheet for this map if you want to reduce those long shadows just a bit.
Last map of the Year
WIP Inside a giant tree
