- Loopysue
- 9,990
- Member, ProFantasy
- 9,866
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
[WIP] Hyboria Map
Have you thought of making the continent lines thin enough to match the average thickness of the ink in the mountain lines? That will make the coastline look less distinct, but you can counteract that by adding a Glow effect to the LAND sheet, set to Outer and a dark grey, so that the water is shaded away from the land a set distance all around.
I know the old 'I'll know it when I see it' issue. I have that myself quite a lot. So lets try to get the coastline looking good first, and then maybe you will have a better idea of what you want for the land.
Are you going to use this with a pure white background, or are you looking to add a subtle paper texture? A plain white background is what you want if you intend to use the map printed on paper, which will be its own paper background, but if you only ever intend to use it as an image file you might want to add the paper texture in.
Community Atlas: Errynor - Aunty MacKassa's Home & Vehicles
CA style development - "Darklands City" (issues for September and December 2021)
[WIP] Hyboria Map
I copied the existing land shapes to the COASTLINE sheet, and then hid everything but the land sheet and turned that solid white. With the COASTLINE in place there was no longer a need for the glow, so I switched it off, though it is still there in case you want it in the future.
I thought, but couldn't be sure, that there was a COASTLINE entity as well as a LAND entity in this style. It sounded like there should be. The drawing tool draws an identical polygon on both sheets. All I have done is replace the missing poly on the COASTLINE sheet.
[WIP] Hyboria Map
Make a new sheet over the top of everything else (bottom of the list), then either import a seamless bitmap fill of your choice and draw a rectangle of it on that new sheet to cover the entire map, or import an image of parchment that is of a suitable size and resolution on that sheet.
Add a Blend Mode effect to the new sheet and set it to Multiply and 100% opacity.
If you have used an image instead of a seamless bitmap fill you will also need to use the DELAYDRAWSYM command and set it to zero, so that the Blend Mode effect works.
Ushuaia - End od the World - Land of Fire
WIP - Maelgoth
Inbetween failed video takes distraction
night landscape
