- Loopysue
- 9,991
- Member, ProFantasy
- 9,866
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
TRACE: how !!!!
Hi Jay - it's me, Sue Daniel from the FB Group :)
Thanks for showing us a screen shot. That helped to see the problem a lot better.
I've not seen this happen before. A quick discussion with Remy, and he came up with the suggestion that you try reinstalling the latest update, and if that doesn't help to send this to Tech Support for advice.
Perspectives 3 - Log Fort
If it can be done that way, all good.
Another thing you might consider is making seamless fills using your clumps of grass. I can show you how to do that if you like. I made all the seamless forest fills for my overland styles that way. First I made the symbols, and then I used them to make a seamless fill in CC3.
Server Move
Watabou Cities SVG to DXF Conversion
As far as I am aware it is free to register with CloudConvert and just carry on as normal - if we're talking about the same source as is mentioned in the 2020 January CA issue. Ralf did a live stream, and ended up running into that barrier right in the middle of the live stream. He just registered and everything was fine.
ATLAS WIP: The Vale, Panaur
EMF conversion Issues
Can't make new CC3 exports in FT3
Nebula ? I'm looking for nebulae bitmap fills or symbols
There is a 2000 px version of the same thing in my album here. I wasn't able to do a larger version as a png, and couldn't upload it here because of the size. This is a very large symbol, and probably the largest I can do.
https://forum.profantasy.com/profile/gallery/4615/Loopysue/161
The alternative is a jpg background image.
I've also made the nebula itself a bit brighter than before so that it shows up a little better.
Greetings
