- Loopysue
- 9,991
- Member, ProFantasy
- 9,867
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Vincula, the City of the Mountaingate
[WIP] Cliff City B&W
Recommendations for a mapping set/settings to use for a large snow-covered city?
The fills associated with any particular style only usually load automatically with that style, so you would not expect to be able to access DD3 fills when you have created a map in one of the CD3 styles.
Remy Monsen shows how to import specific fills from other styles into your current map individually in this Live Mapping Session here:
There are other ways of importing fills too. If you just want the whole set from another style into your current map you can either import a map in the other style and press ESC at the moment you are invited to paste it, or you can use Import Bitmap Fill Styles in the Tools menu. The first option is faster if you only want to import the fills from one other style. The second option is faster if you want to import all the fills from several different other styles.
An important thing to note here is that importing the fills only gets you the fills, not the drawing tools of the other style. If you also want the drawing tools to go with your imported fills you will need to pick them from the Drawtools style dropdown box at the top of the Drawing presets dialog (which opens when you click the Drawing Properties button |CC2PRESETS|on the top toolbar)
EDIT: Ninjad by Remy, but we seem to have worked together without realising it :)
Hello! I am DoubleDouble
Hello
WIP: Lost Temple of Ankun-za Level 2
I was once told that it was good to have a decent area to fight in. I don't know how true that was, but the gamer who wanted more space to play around in was very satisfied with my modifications, which meant I had one reasonably large room.
What is the scale here? Some indication would be good. Either a grid or a little white square to show 5 or 10 ft square.
Live Mapping: 3D Modelling Symbols
Too early for a CC4 wishlist thread, or is it timely?
Atlas Ferraris Syle
Hitting B with Corridor No longer breaks the wall
