- Loopysue
- 9,992
- Member, ProFantasy
- 9,867
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Vincula, the City of the Mountaingate
I like where you are going with this :)
If you want to get rid of the green glow on the industrial grey move the sheet with the river above it in the list (which will place it, and its sheet effects, below the grey area in the map). You may have to juggle the sheets around a bit, but if you can't get them in the right order for things to show the way you want them to you might have to add a couple of new ones and move things from sheet to sheet to make it so.
After CC3 prompts you to autosave, if you say Yes, does it wipe all Undo memory?
Its not so much about house shape, but the sum of all the details together. I've done about 10 more minutes on this map tweaking fills and adding a few dormer windows and extensions. With more time it would be a reasonable village map, though it needs a focal point like a tavern or something. That one building I would take some care with. The rest are just simple houses after all.
Don't forget that you can also make your own house styles to add to the mix, but you will need to do that first using the House settings and saving your own new styles. I have loads of my own.
Grimdark Fantasy (renamed "Darklands") - development thread
Live Mapping: Complex Room Shapes
Increase detail level on sections of FT3 map
Sadly, you can't reverse the import directly. When you export a map to CC3 you lose all the 2.5D height information, so the best you can do is use the outline as a pattern overlay to re-sculpt your island a little larger than it was before
Alternatively, you can zoom in to the island and export that alone as a CC3 map. FT3 will export whatever is visible in it's window at the time of export and nothing more. It should give you a much higher resolution CC3 map of the island.
Random City Generator
WIP: Manor house (problem with walls)
