- Loopysue
- 9,992
- Member, ProFantasy
- 9,868
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Tool control background fill color
Remy is right.
Just as a side note here - the view window colour setting requires input from the user to do anything. You have to give it the number of the colour you want from the palette. For example 15 is white, and 0 is black. I wouldn't worry about that right now though, since the view window colour isn't anything to do with the real problem.
WIP: First BattleMap: Ice Caves
Q on Copywrite & Licence
Hi Gameleaper :)
Going on the EULA, and on Profantasy Team comments on similar threads, I suspect the answer to quite a few of those questions is a 'no'.
The EULA can be found here: https://www.profantasy.com/service/license.asp
Don't worry - Its not one of those really long ones.
If you are still in any doubt after reading it the safest way to go is by contacting PF through your Technical Support contact form on your account page.
Fantastic castle illustrations for reference
Banners
Fractal Terrain 3 beginner
No sweat.
Most of what I just said is available in more easily digestible bit-size pieces in the help tool you can open from within FT3, so you can take your time to learn stuff.
Exporting smaller regions might help a bit, though I'm not sure if it will help as much as you want it to. Whatever resolution the export is set to is the one you will get, whether its a whole world, or just a small continent.
Banners
SciFi Outpost - the Files
New Mouse
The fault appears to be more frequent if I'm not actually using the mouse. For instance when I'm using my tablet to draw things with. So for now I just unplug the mouse when I'm drawing, and plug it back in when I'm not.
If the good old days it was possible to do everything using the tab key. It doesn't seem to work that way anymore. Forms are the worst. But don't worry. I will order the new one tonight, and if the worst comes to the worst I can use the tablet. It's better than tab, though not much ;)
