- Loopysue
- 9,992
- Member, ProFantasy
- 9,868
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
FT3: Removing an inland sea?
Since I am not an expert by any means, and know even less about brushes other than the prescale offset brushes, I think that unless you have several backups saved that you might be able to work forward from again, you might need help from someone like jslayton (Joseph Slayton), or one of the other more seasoned FT3 users.
If this is a world you have re-imported back from Wilbur, having done something like CA155 to it, the only recommendation I can make that might help is to go back to the pre-Wilbur FT3 world and raise the lake using the prescale offset brushes at that stage and take it through the process again without the lake from the beginning.
At any rate, I recommend avoiding the tools that increase or decrease roughness. They are pretty difficult to control and can cause more problems than they solve unless you have an extremely light touch.
Finding Joe Sweeney's CC3+ videos
@Wyvern - I think Remy is working on just that ;)
Forgotten Realms Atlas Project
October Community Challenge - City Streets - VOTING POLL in first post
I can't start until the last 2 weeks of the month, so I will make my choice if there are any left at that point, Remy. It wouldn't be fair to 'bagsy' the best plot when I can't start straight away.
So the rest of you had better start snatching up the easier bits I can see there as quick as you can, because on 16th I'm coming back to take my pick!
Project Spectrum - Part 2
Custom rectangular grid - how to add coordinate labels
It is likely that the offset 70 S line is still there but hidden by the white polygon on the SCREEN sheet. Try hiding that sheet and see what you find.
The SCREEN is there to hide things that fall half in and half outside the map where they can't be trimmed. Symbols, for example, can't be trimmed so have to be hidden to tidy the edges.
If you want something to show on top of the SCREEN sheet you need to put them on a sheet below that one in the sheets and effects dialog. You can either move the TEXT sheet down to that level, or make a new one, called TEXT on top (for example) and make sure that one is active when you place the labels you want to see on top of the screen. If you want to move existing labels to a new sheet at the bottom of the list, use Change Properties, or right click the hourglass and use Move to Sheet.
That should solve your visibility issues, but it may simultaneously cause a new problem, where the map may export to JPG minus the border. There are a number of ways to correct this, but I will wait to see if we have cured this problem first.
Ok, well I've given you all a few days to snap up the best bits :)
Please can I have number 2, @Monsen ?
I will make a start on it in the last couple of weeks of the month.
CA161 Hedgerow vc missing black lines?
It does seem to be the case.
I don't think anything can be done straight away, but I might be wrong. Ralf is the one who would have to decide whether to do it now or to add it to the list of corrections for the end of the year.
Whichever, he needs to know about the problem. Please can you do a Tech Support request for it?
FT3 to CC3 export
