- Loopysue
- 9,993
- Member, ProFantasy
- 9,869
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Do you use a tablet?
Live Mapping: Fantasy Hand-drawn Part 2
Using End Modifier Tool and a bit confused
At the point in the process where you right click (after you have picked Copy from the Edit menu) you should get this pop up
The Window option is 6th in that list. Pick it and then continue with the process. I think the bits you don't understand will become clear to you once you start with the Copy tool in the Edit menu.
If it doesn't, just say.
Wish List: City/Dungeon Top-Down Mountain Peaks, Ridges & Crags
Delete Duplicate Entities
Inclination not working?
I was just about to say the same thing, but since Remy has already said it here are some screen shots illustrating those points.
Point 1: 2 shots, starting with the default inclination settings and then showing a really low sun such as shortly before sunset. The shaded side of the rooftops darkens.
Point 2: (Actually shown above at the same time). The Activate lighting panel is completely turned off with no effect in this map where there are no dungeon lights present, or the necessary sheet effects.
Point 3: The shadows on the buildings are "Wall Shadow, Directional" type, and respond to the Azimuth settings correctly if I reverse the angle from 135 to 315.
Hex Crawl Test
CC4 Overland Development Thread
Hand painted using a Wacom Intuos and Affinity Designer. It's not the same, but I do also have Rebelle 7. Unfortunately, Rebelle 7 doesn't allow seamless canvases, so the texture tiles would be a problem. Artrage (which I also have) does allow for seamless canvases, but I find the result less realistic than Rebelle.
I will find a workflow.
Virtual hand painting takes about the same time as messing around trying to do it other ways. It's all very much the same once you no longer use traditional materials.
