- Loopysue
- 9,996
- Member, ProFantasy
- 9,871
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Monsen IR command Error Responses?
I mentioned the fact that the chameleon hills don't work well in the arctic regions. The same applies to the uneven ground texture. Maybe that should be noted in the margin somewhere? It's because the arctic fills (snowfield and ice) are too white as a base for the sheet effects. If you really wanted them to work on the ice and snow you could (given some time) add a new uneaven ground terrain sheet and fiddle with the blend modes to get something more noticeable, perhaps. No promises though. I tried it and failed. That's why you have a snow hill drawing tool.
There are no snowy forest fills, but you have made a good solution.
The map size only affects the symbols, not the fills. The fills will be the same scale no matter the map size.
WIP: ESTONISCH CONTINENT BIRDSEYE
Can't find 1930s Travel Guides in Floorplans
WIP: need some help with making text more visible
Here is a really good blog by Remy Monsen that explains everything you need to know about the colour palette.
The palette I attached to your drawing is my default 'Save Custom PAL', which I just reload every time I need it. It's slightly less jarring than the actual default palette, and has fewer pinky purples and more of everything else.
change background colour
So it is meant to be the MAP BORDER?
Ok. Freeze the BACKGROUND layer so you don't grab the background poly, then unfreeze the GREEN BORDER layer and grab the line to change it's width to zero and place it on the MAP BORDER layer. Then freeze the map border layer and unfreeze the BACKGROUND layer, so you can get to your background.
