- Loopysue
- 9,993
- Member, ProFantasy
- 9,869
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Best approaches for tree shadows?
It's an interesting idea, but the reason it's not responding to some of the sheet effects is because you are using symbols instead of polygons.
To best copy the Forest Trail tree shadows, instead of using copies of the trees on the tree shadow sheet, trace the rough outline of each tree with a black polygon on that sheet. Then use the same sheet effects as are used in Forest Trail for the tree shadows. I think that was a blur and a blend mode. Blur to soften the edges, and a Blend Mode set to Multiply, and about 20-30 percent. Adjust to taste.
Birdseye Continental - style development thread
Question about CA143 Asian Town "well" symbol
Unable to access styles on my system
It is unlikely the installer has put the files anywhere they shouldn't be, but if they have somehow ended up in the wrong place it is probably easier to try reinstalling that package.
I've never used that particular installer myself so I don't know if there's a repair option if you just run it again on top of itself (so to speak). Worth a try?
If a reinstall doesn't work please contact Tech Support through the form on the Support tab of your registration page (when you log on to your account on the main Profantasy website).
[WIP] Community Atlas: Kumarikandam - SE Tiantang Region
Dragon sheet
Dragon sheet
forest fill tool
You can't change the scale of the forests you've already placed. You will have to delete or undo them.
Check the scale of the single trees you've placed, using the List option in the Info menu.
Then open the Drawing Properties dialog and alter the default symbol scale to match the scale of the single trees, and place your forests again. (This shot shows the default symbol scale for the style I am working on at the moment is 1).
Don't forget to change the default symbol scale back to what it was before you altered it once you have done your forests.
