- Loopysue
- 9,993
- Member, ProFantasy
- 9,869
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
ALPHA BLUR question
About the second question.
2 is the limit for drawing tools. Other than that you will have to manually copy them to other sheets.
I've used a similar method in my DD4 example map (sorry - can't show you that yet) - not Color Key, but a sill sheet. I have sills that match the walls. The windows and doors only cut the walls. When the sill appears in a doorway it looks like a threshold. The trick is to not put anything more than a slight glow on the sills so the eye interprets it either as a windowsill, or as a threshold, depending on context.
After Day's of Watching Videos
I found the notable blog, though I don't know if this will help you or not. https://rpgmaps.profantasy.com/exporting-coloured-topographical-maps-from-ft3-to-cc3by-andre-franke/
That's @WeathermanSweden's work ;)
Export lights to Foundry
How do you Add Cave Walls?
If you hide all but the floor sheet you can then copy the floor you have drawn onto the walls sheet. Then hide all but the walls sheet and use the Change Properties button to change the fill and line width of the ex-floor. Giving the polygon a line width will make it into a wall around the same shape.
Make sure you also change the layer to WALLS as well as the sheet, and you will be able to cut doors through the walls with the cutting symbols.
Birdseye Continental - style development thread
[WIP] Fantasy World
Ricko's Questions
