9,992
Member, ProFantasy
9,868
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Is there any way to adjust contrast?
    Would this work for you?
    A single RGB Matrix Process sheet effect on the 'Whole Drawing' level (radio button at the top), with everything set to 1 except the end column.
    The only grey I can see in my amazing test map is where the structure symbols are red.
    il mietitore
  • Community Atlas - NE Arum Nur Highlands
    I am surprised it hasn't knocked everything off the edge of the map yet.
    roflo1Quenten
  • Four weeks later and here's my first map!
    Hi Martin :)
    That's a really great first map (and I'm not just saying that because you worked my name into the labels).
    lifelong_buildingroflo1
  • DD3 Room/Floor/Wall Drawing tools
    Hi Viepyr :)
    Click the little window as the far right end of the Status Bar (top of the window) where "FS:...." appears.
    Click the "Bitmap fills" tab in the dialog that appears, and select the fill you want to rescale from the Fill Style Name dropdown box.
    In the "Specifications" sub-panel there is a checkbox called "Scaled" with a "Width" and "Height" specified next to it. Make sure that box is checked and scale the fill according to how many map units wide and high you want it to be.
    GlitchJimP
  • Community Atlas - Forlorn Archipelago - The Bleakness - Dungeon of the Dragon
    When you fractalise smooth polygons they become straight ones again, so you will have to make them smooth again if you want them to be smooth polygons.
    Ricko
  • Live Mapping: E Prybylski 2 and Political Maps
    Hi everyone! :D
    In this week's live mapping session Ralf will be taking a look at August's Annual issue - the second part of the E Prybylski overland style, and how to do political overland maps.
    Come join us live and join in the discussion on Youtube here:
    https://www.youtube.com/watch?v=b_QMpUP2MmU
    Or watch it here on the forum if you prefer.
    JimPWyvern
    We thought it was one of your secret entrances, Jim.
    JimProflo1
  • "Dirt and Grass Light Bitmap" won't load even on a new map
    Sorry - I had to go to bed shortly after I made that request, so I wasn't any help at all.
    When I opened the map this morning there were only lines on the background and no background fill polygon, but there were a few other things not on the right layer. Use List from the Info menu on everything visible when the map opens and you get this:
    Either the background polygon wasn't there to start with or was accidentally deleted. We may never know.
    Only the map border itself should be on the MAP BORDER layer, though it can be on any sheet. Whatever is on the MAP BORDER layer defines the edge of the map within CC3 and controls how it is exported if the "Restrict image to map border" option is checked in the export options dialog when you export your finished map.
    I see you have replaced the frame and drawn a screen on the FCW you shared. This can be done more efficiently after you have set up your custom frame by using the screen commands explained in this blog by Remy Monsen.
    https://rpgmaps.profantasy.com/leveraging-the-new-features-of-cc3-update-26/#more-6495
    Since things are a little muddled on this map, and since I don't think you started the actual drawing part of it yet, I recommend starting a fresh new map and using the sheets (not the layers) to hide everything but the map border so you can modify that first, then showing all the sheets again and using the relevant collar commands from that blog to generate your screen.
    Shout again if you have any more problems.
  • Passing of Jerry Thiel
    I think all those of us who have been here for more than a couple of years will remember Jerry's beautiful maps, and how helpful and kind he was to everyone. I never met him face to face, but his online presence was a shining example of how to be a decent and loveable human being.
    seycyrusWyvern
  • Easiest way to migrate to a new computer
    Oddly enough I never thought of doing it that way at all. I just redownloaded all the installers and reinstalled everything fresh and new on my new machine last December. Although it takes a bit of time it means that if anything has been updated in any of those installers I get the updated versions. The drawback is if you have made your own symbols, fills and styles. I had to transfer those across as folders and files and put them in the right place.
