- Loopysue
- 9,991
- Member, ProFantasy
- 9,867
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Moving objects in front of or behind in same sheet.
Something I didn't know...
The way symbols with some transparency are drawn is different to the way symbols with no transparency are drawn. One of the smoke symbols (the one we both had trouble with) has some transparency and that's why we couldn't get it to come to the front.
The best solution is the new sheet option in this case. As was pointed out to me it's probably best that the smoke doesn't have the same sheet effects as the bushes anyway.
Can anyone help me figure out what this awesome map style is?
Looks very similar to the 1930s Overland Map style from the 2013 Cartographer's Annual.
a magic? map
Having trouble with settings
You have to click Apply to see the result.
And yes - most of the terrain sheets have the same issue.
The difference between those two settings is that the Percent of View Width is really huge at '10'. That's 10% of the width of your window. If you set 10 map units thats just 10 miles rather than possibly a few thousand miles.
resizing mapping area
Live Mapping: 1930s Street Maps
Hi everyone! :D
This week, Ralf will be creating a map with the Baedecker-inspired 1930s Street Maps style from the Cartographer's Annual Vol 5.
If you don't like YouTube you can watch it right here:
Or you can come and join in the live chat here: https://www.youtube.com/watch?v=pzWirHveCM8
Hedge Tool
Color key isn't working again
The Colour key works as long as you have these three things set up correctly:
- The cut out shape is on the same sheet as the thing you want to cut.
- There is a Color key sheet effect on that sheet, and its set to the same colour as the cut out polygon
- The sheet effects are turned on.
If you want to cut the same hole in other sheets, for example you've cut a hole in your land that you want to cut in the terrain that lies on it, then you will have to set up the same thing for that sheet as well. It doesn't work for multiple sheets, but only the one its on.
A Color Key only works on the one sheet that it's on. If you want to cut things on other sheets you need to make a new Color Key on that other sheet and add new colour cut out polygons to that sheet above the polygons you are cutting.
I actually missed a point above. The cut out shape must be on top of all the other shapes on that one sheet.
Do any styles have East European Symbols?
