- Loopysue
- 9,991
- Member, ProFantasy
- 9,867
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Looking for Symbols of D&D style Dice
Little Bighorn Battlefield Map
Community Atlas: Errynor Map 33 - Hwael Igland
Forest Trail project - part 2
@EukalyptusNow You're welcome :) Those two fills were more of an accident than anything else. I play with making textures when I'm thinking, and those two just cropped up - one a modification of the other.
The bridge is in sections anyway, so you can built it with or without the damaged section.
The method you suggested for the stepping stones is one that I created as a multisheet symbol used in one of the example maps for part 1, but for some reason I forgot to add them to the catalogue. I'm currently experimenting with specifically drawn ones, but it is difficult to draw stepping stones that fit all 3 states of the river (calm, fast and white water). There is now just a bit less than 2 days to go to handover, so these are not a definite inclusion.
help with trace
Live Mapping: Forest Trail 2
Hi Everyone! :D
In this mapping session Ralf will preview the bonus issue of the Cartographer's Annual 2022: Forest Trail part 2.
Watch it here:
Or you can join in the show or see the recording of it on YouTube here:
(WIP) Bindak's Retreat - An Asian Pirate Hideout
Community Atlas - North West Berenur - Azin Forest
Does RGB Matrix Process work on Symbol Sheets?
It's mainly to do with the drawing order.
Symbols are by default drawn twice to ensure the semi-transparent pixels are not detrimentally affected by the sheet effects. However, the whole map effects are done last of all, and will affect the whole drawing, no matter how many times everything has been drawn up to that point.
You can disable the second drawing of the symbols using DELAYDRAWSYM, but this will damage semitransparent pixels in the symbols. You might not think there are a lot of semitransparent symbols but in truth the edge of nearly all symbols is antialiased, so there will always be a very thin fringe missing, and that may be enough to make the symbol look odd.
DELAYDRAWSYM automatically reverts to 1 next time you open CC3.
Having said all of that there are notable exceptions to the rule. Most house symbols will respond to colour modifying sheet effects because of the presence of map files, which control the shading of rooftops. City Cliff symbols also have map files, and will also respond to these effects.
What Style for 1600-1700 West Indies Map
If you decide to use any of those sets mentioned by pvernon, there is a comprehensive section in the Tome of Ultimate Mapping covering how to create your own symbol catalogues, or if you prefer to watch there are a couple of videos created by Remy Monsen here:
https://www.youtube.com/playlist?list=PLulP-cGMLxw4qTpXfilRHgbDUg8WvrEX2
