- Loopysue
- 9,991
- Member, ProFantasy
- 9,866
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
[WIP] Bā Dà Chéng Shì
Where can I find palm trees and beach items?
Oh I think those are palm tree tops, which are isometric and meant for creating forests where the trunks wouldn't be visible, but I've seen other top view maps use them a bit like bent over palms. I'm not sure they would really work as far as resolution goes either, since you would have to enlarge them beyond the limit where rasterization would occur to be a realistic size for a dungeon map.
[WIP] August Mapping Competition -- The Blue Rose Tavern
[WIP] August Mapping Competition -- Vertshusen Distillery
If you rotate an ordinary polygon the fill stays put.
You can make the fill rotate with the polygon by making it an aligned fill. If that is what you want it to do, hide all the sheets but the FLOORS sheet and right click the polygon tool. Pick "Shaded Polygon, Angle by Edge", and click the edge of the polygon you want the fill to align to. This is like the shading on a house roof, so to take out the pitch information that shades it darker or lighter depending on which way it is 'facing', type EDITSHADING, hit Enter, and pick the shaded polygon floor. Then in the dialog that appears check the "Shade only copy" checkbox and ok it.
Humble Bundle 2022 - Contents?
What was the bug in HCC3's installer?
Hi @Virtual Nomad, and welcome to the forum :)
As I understand it there was a problem with the installers not all being present, discovered yesterday. A new one was immediately uploaded, but just as the DL speed seems a bit slow, so is the UL speed from our point of view. I was told it would be several hours before it was ready.
That was nearly a day ago, so I expect that if you are missing a few installers you can get them by re-downloading the affected bundles.
Sorry for any inconvenience.
[WIP] August Competition - The Southern Gatehouse
Making more detailed maps
