- Loopysue
- 9,991
- Member, ProFantasy
- 9,866
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Teaser or Bug?
Strange artifacts from the Bevel sheet effect
That's a form of 'transparency acne', where the current rendering engine in CC3 suffers an error if a pixel on one sheet is the same colour as the underlying pixel on another sheet. The identical pixel is interpreted as a hole exactly one pixel in dimension, and the sheet effects are applied to its edges - hence the buckling effect when you have a bevel. The Bevel Lighted effect creates little craters, and the Edge Fade Inner creates telltale circular holes.
To cure it you can either use a different texture for the affected parts, or insert what I call a separation sheet. You can do that by adding a new sheet just underneath the one with the problem and copying the affected entities to that sheet. Then turn them purple, or some colour you can be sure isn't in the texture. 227 is a good colour to use.
Fast Marshes Tutorial
Live Mapping: Computer System Maps
Live Mapping: Journey Maps (Cartographer's Annual Vol 3)
The Creepy Crypt project
Mallory Steading - Dungeons of Schley Map
Does CC3 licence allow the product to be use by multiple Windows 10 accounts on the same laptop?
Hi Gianluca :)
I recommend you contact Profantasy directly with your question.
The email address for licencing questions is at the bottom of the list of contact emails on this page:
Live Mapping: Modern Atlas
