 - Loopysue
 - 9,989
 - Member, ProFantasy
 - 9,864
 - June 29, 1966
 - Dorset, England, UK
 - Real Name
 - Sue Daniel (aka 'Mouse')
 - 27
Help adding the monthly content to existing map!
WIP Tropical Area on My World
Any Oriental style symbol sets out there? (CC3+)
Making streets (what am I doing wrong?)
This is part of a Live Mapping session demonstrating the Ryecroft Town annual issue, but the Street tool works the same in any style.
Understanding impact of changes and related saves
Drawing tools are part of the style template, so saving a modified tool will cause that tool to stay saved that way. It is better to pick the tool you want to change and then press the New button. A new tool with the same qualities as the one you wanted to modify will be created, and you can name it as you see fit. When you modify this new tool and save it, the tool will be saved alongside the other tools in that style, but it won't alter any of the tools that came with the style.
Similarly, if you get into modifying the textures and symbols of a style it is better to copy them and rename them as your own variations before you work on them.
Edit: Ninjad by a much better answer from Remy :)
Live Mapping: Modern Cities
Is there a discord? Also struggling with this awful controls, especially when it comes to floors
CA style development - "Darklands City" (issues for September and December 2021)
Problem with lighting
This looks like an issue with the Maximum Pixels Per Pass.
If the image resolution is quite large the rendering engine makes more than one pass to render the whole image. There is a percentage overlap but this may not always be enough to capture the source of a light that lies just outside the edge of the current pass. That means the pass may be calculated much darker than it should be.
Type EXPORTSETMPPP and hit the Enter key. In the command line you will probably see the number 4 million. Type 40 million (without any commas) and hit Enter again. Then try to export your map again.
WIP: Now, for something completely different...
Looking like a really attractive land shape there, Calibre :)
The interesting thing about the idea of centreing or not centreing the shot. Painters are taught never to plonk things centrally without thought for the overall composition with emphasis on thirds, fifths and sometimes sevenths - diagonals and golden rectangles... all kinds of stuff I learned and subsequently forgot over the years, while photographer's are taught exactly the opposite. Place the subject central to the shot.
