![Avatar](https://forum.profantasy.com/uploads/userpics/706/p4NPJ0AID2TIV.png)
HelenAA
HelenAA
- HelenAA
- 986
- Member
- 393
- Surveyor
- 6
Reactions
WIP, suggestions please
it was a reflection on the small chain of 'islands' that gave me the idea for the name, @Loopysue, although you've missed Katisland! :D That will stand out better when I change the colour of the islands.
The Haunted Lands
I find reading decorative fonts difficult when small, @Ralf but I'll experiment with slightly decorative fonts today and post the results.
unable to change colour for lines
link crevasse symbols ???
map disappears
I'm sorry @JimP - I had a chaotic weekend. You fixed it wonderfully, thank you for your help. What does movesht actually do? If I get myself into a similar mess I'd like to know what command line commands do so I apply the right one first time!
WIP Ruins of Charn
yes, Sue, I did, and it didn't work 😥. I'm thinking of putting something like a dot hidden under the map border on an otherwise empty sheet and doing a gigantic blur below the text sheet! might work, might not.........!
EDIT: I had to step back a saved map because none of the sheets had the RGB Matrix settings. Thankfully I tried the RGB first thing so I only had to re-place 3 symbols after stepping back.
can't select symbols
WIP Ruins of Charn
crops
sure - as soon as I can find it!
sorry about the entire screenshot - couldn't crop it. The buildings are ALL isomectric as are the market symbols.
EDIT
here's a better one @Loopysue =
crops
