Jeff B
Jeff B
- Jeff B
- 5,899
- Member, Betatester
- 1,238
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
[WIP] August Mapping Competition -- Vertshusen Distillery
Print Issue
Sue,
The edge effect works fine if you change the setting to use map units instead of Percent of View width and move it below the glow effect. suspect the effect is grabbing the purple glow. As during some playing around I had the entire CC3+ display window purple with the effect on.
PNW,
You should be using the map units option for your effects it will give you less problems than Percent of view width.
[WIP] Winter Village
City of Torlok
Thank You for your comments. I would love to add it to the atlas and I will take you up on your offer for help to find a place, Hope that also includes letting me what I need to do for notes and stuff before I give it to Remy.
Ok I read Sue's instructions and did what I could for cliff shadows. dropped the unused sheets and renamed a few along with moving stuff to the correct sheets. I added the key and text to the maps.
Comments and Suggestions Welcome
@Wyvern I adjusted the paths added some frozen mud should be able to see dirt on side of paths now. Replaced tree in the i to a snowflake (cheated found a snowflake dingbat), Adjusted shadows on glow on bare trees. I added a light in lower right side to add some light in that corner and added a lighted tree from the house across the creek. (Original light from lower left was just to highlight the snow text.)
I know the eagle is out of place in the night scene but I do like it (maybe it's an owl that looks like an eagle). Think of the deer as targets for archery practice. Just to mix thing up the wildlife do move now.
Thank you for your comments.
Adjusted the tinting of the snow words to make it stand out more. Replace the stock frame with and day and night version frame.
This project is actually for the Annual Holiday Photo Card contest at work. I asked if I could submit a none photo, they wanted to see what I meant so I showed them the first draft. I was told I could enter even though it's not a photo. So some of the additions and changes I made were from comments made by people at work. They also wanted the night lighting increase to lighten the entire image up. It also reflects early evening so the deer and eagle don't seem so out of place.
as always comments and suggestions are welcome and high-res version in gallery
WIP: Exeder
Endoria
@Loopysue Thank You, I will be glad to see the printed version of the regular map after 6 months of work that I put into the overland map. I'll get a couple weeks break to work on my stuff then it's dungeon maps again. It was a really good learning experience.
[WIP] Atlas Contest : Ingensteds Village, Seal Island, Alarius
Community Atlas 1000th map Competition - with Prizes [August/September]
