Jeff B
Jeff B
- Jeff B
- 5,439
- Member, Betatester
- 1,115
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 8
Reactions
Live Mapping: Herwin Wielink Isometric Dungeons
[WIP] Winter Village
Forest Trail project - part 1
My First Floorplan: Cybperpunk Club
[WIP] Project-A
CC3+ Closed - double click on .FCW file 16 seconds to open. (Effects are on when file opens)
Click on toggle show light symbol buttons (Thank you Remy for that great tutorial) 15 seconds
Toggle global sun off = 1 second
toggle global sun back on = 15 seconds
toggling effects on is also about 15 seconds
The above testes were for the default size on screen if I zoom in to fill the window with the image it takes 18 seconds to redraw.
rendering effects always triggers laptop fan to turn on
rendering to jpg
setting 5000 5000 300 ai 35% (exportsetmppp = 40000000) = 6 minutes 40 seconds it takes about a minute to get to the LIGHTS GLOBAL Sheet. It look like it is taking 5 minutes for the lights to render after the LIGHTS Global appears and then the message about writing the file to a jpg appears.
setting 5000 5000 300 ai 35% (exportsetmppp = 80000000) = 7 minutes and 20 seconds
Hope this helps
Ok use the following setting to render the image.
Enter this command:
EXPORTSETMPPP - enter key
80000000 -enter key
then do your save as and select the image type you want and adjust options as below if needed. You can change the Width and height if you want but don't go too far above 35% antialias
Here is how I set up the options in the save dialog before saving the jpg / png
Also if you want editing lights to be easier create a sheet for each color and make sure you put each color light on the correct sheet. That way if you want to edit the pink lights hide all the other color lights and your light list will be easier to deal with.
Yep looks good now. Glad I could help. The lights behind the bar don’t look so strange now.
You have a purple/pink light in the upper left corner that appears to be set at 180 and facing the wall. It has a very hard line caused but the setting but the same corner in the lower left has a 360 light. I would change that upper light to 360 to remove the long harsh line it is creating unless that was the intent.
Try changing the light at 33,187 from 90 to 360.
Deepzoom images for web display
Cc3+ text on non cc3+ map versus photoshop?
Live Mapping: Classic Fantasy
For the profantasy videos what I do most of the time is play them as background noise and when I hear something that interests me or is some tip I haven't seen or want to use I'll pause it, back it up, watch it, try it out, then go back to the background noise mode. Works really well for me. Written stuff I really like in paper form but now a days they are all PDF's which works. I can blow up the display scale for my old eyes and can do searches but still like paper better as I can have it in front of me while I'll doing it instead of jumping between windows or digging my ipad out to read them on it.
