Jeff B
Jeff B
- Jeff B
- 5,899
- Member, Betatester
- 1,238
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
Could someone please convert some .FCW files for me?
Question - Darklands - Active Sheet Effects - Rivers Run Green
Suggestion to make monthly issues separately purchasable
As someone who has purchased the annuals through the years I can tell you that there is no single year where everything that was released was useful to me at the time and in some case still is not. What I can tell you is that you will find that down the road something you thought was not very useful when it was released does become useful. This has happened numerous times recently has I expand my mapping and learning. So even if you have a couple of the issues in an annual from a humble bundle deal and currently only see using a couple more from that same year it is worth getting the entire year.
The $40 cost of the annual is well worth it even if you only use a handful of issues from that annual. There is a lot of value in the annuals and at $40 each and it is a cheap purchase. Yes to buy all of them even at the 50% off seems expensive but compare it to other purchases you make. How much use with you get out them is what is important. Let's say 1/2 the issues in an annual you will use, now compared that $40 cost to buying new video game (which you will set aside once you complete it) or even a dinner out, the annual content will last much longer that either of the other two purchases and you will have extra issues to explore down the road as you grow in your mapping experience.
Community Atlas - Arthenn / Berenur
Text inside a box
[WIP] Haunted Mansion
Your problem is two fold.
1) you have 2 lights on top of each other - We can deal with that but change the radius of one of the lights to 400.00
2) Change Width in degrees to 360.00 (you are set to 0 and that is the problem)
3) option change the light with the smaller radius to a different color.
Yes this is a render not a screenshot.
I also used the collar command on the file to hide the overflow objects beyond the screen.
Forgotten Realms Interactive Atlas repairs.
Forest Lair
Thank You for the suggestions I'll look at those. The coast line is two different layers so I'll see what I can do.
I changed the water shoreline and tried to fix the grid but the grid still in not right. Tried black but changed to dark brown. Seem to have more of a beach shoreline effect than before.
Just a map
[WIP] August Mapping Competition -- Vertshusen Distillery
