Jeff B
Jeff B
- Jeff B
- 5,439
- Member, Betatester
- 1,115
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 8
Reactions
[WIP] August Mapping Competition -- Vertshusen Distillery
Forest Trail project - part 2
New install
My First Floorplan: Cybperpunk Club
Ok use the following setting to render the image.
Enter this command:
EXPORTSETMPPP - enter key
80000000 -enter key
then do your save as and select the image type you want and adjust options as below if needed. You can change the Width and height if you want but don't go too far above 35% antialias
Here is how I set up the options in the save dialog before saving the jpg / png
Also if you want editing lights to be easier create a sheet for each color and make sure you put each color light on the correct sheet. That way if you want to edit the pink lights hide all the other color lights and your light list will be easier to deal with.
