3,153
Member
5,382
24
  • Playing Card County Maps
    To answer some of the questions here, yes these were genuinely used as playing cards back in the day, but they also had an educational aspect, described sometimes as a sort-of early pocket atlas. The full sets included the usual 52 cards, an explanatory extra card, and a title card with a map of England and Wales divided into counties. The cards were among the first maps to show roads. As the sample here shows, they also gave the county dimensions, latitude (they predate the adoption of the Greenwich meridian for longitude in the mid-19th century in Britain) and selected towns' distances from London. It's thought only one complete set of these cards still survives, although there are a few incomplete ones, and more surviving individual cards.
    Royal ScribeLoopysue
  • What B&W Styles are Suitable for Large Maps?
    You might want to redownload SS1 if you don't have the Fantasy or Handdrawn symbol folders available, as there are definitely four folders showing in my SS1 symbol sets - these two, plus "Peter" and "Sean". Unless the contents have been changed since I obtained mine (they are all dated 2016 in my installation, certainly, so that was a while back!).
    I wouldn't rely on the program to automatically change symbols sizes to always look right. I often find these need tweaking, sometimes quite substantially (and not always by the same amount for all symbols in a style).
    Really just have to pick or adjust things to suit per map. Once you've done it a few times, it becomes pretty automatic.
    Don Anderson Jr.JulianDracos
  • Birdseye cut-out problems
    Your first comment sounds like the pink shape is being drawn on the wrong sheet. If you're using a drawing tool to create it, that may be set to a different default sheet than the one your Color Key effect is on. If so, it's easily changed by simply carrying out a Change Properties command immediately after finishing drawing the shape - so before it vanishes (you can check to see which sheet it's drawing on while you're drawing it in the information boxes along the top of the CC3+ screen).
    I'm guessing that the fractal poly's ending up on the wrong sheet too, as there's no reason it wouldn't work properly just because it's a fractal shape.
  • Drawing lakes over forests and mountains sheets with 2023 MonkeyFrog Overland style
    The other key element is the Color Key effect MUST be at the top of the effects list for that Sheet, or it doesn't work.
  • Flooring Maps
    You can use Ctrl+C or the drop-down Edit menu's Copy command, select the items you want to copy over, and then click "Do it", picking a suitable point to copy them from.
    You will need to prepare a new map file first (just set up a blank map in the correct style, and of a suitable size), and have both it and your existing map open together to do this more easily. Providing you open each map separately, that won't be a problem (just use Windows Explorer to find the files you need, for instance).
    DaniUG
  • Community Atlas: Kara's Vale, Ethra, Doriant
    Thanks @Ricko. In cases like this, I simply try to work with the original style as far as possible, and it is practical to "force" the Mike Schley cliffs to work as north-facing, even if it does mean quite a bit more effort. It would certainly be helpful to have some north-facing cliffs in this style already though!
    For the central valley here, I simply added a Solid 10 polygon over the lower part to darken it a little. The effect is very subtle, but I found using the Solid 20 fill felt too obvious, whereas this seemed to help the effect just enough to fool the eye - to me, at least ๐Ÿ˜Ž.
    Royal Scribe
  • Galery of NPC
    I think most, if not all, the character items are indeed from Character Artist, RS - I recognise many of them, certainly!
    Royal Scribe
  • Community Atlas: Aenos Isle North, Demosthenes Swamp, Artemisia
    It's those treasure-hungry young dragons. They keep moving things about...
  • Tracing an existing map on paper or a image file.
    Before you import the image file you want to trace to your CC3+ drawing, make sure you have a copy of the image file in the same folder as your CC3+ map. If you don't do this, you may well end up with a big red cross where your image file should be the next time you open it, because CC3+ can't find it any more.
    There are other ways to avoid this happening, but keeping the files in the same folder is by far the easiest to tell you about quickly here.
    I do this all the time, and it becomes second nature after only a short time; import, rescale, and get mapping!
    KertDawg
  • Live Mapping - Village Battlemap
    Slightly terrifying to watch Remy wearing different thatched roofs as a hat at times on the livestream replay ๐Ÿ˜‰๐Ÿค  (I'm taking time-out from catching-up to check-in here briefly!) The dormer one seemed to work best, though it's not especially stylish ๐Ÿ˜.
    Good stream though so far - even if I have just got a sneak preview of what the final map will look like by dropping-by here mid-replay!
    Don Anderson Jr.Loopysue
