3,239
Member
5,519
24
  • [WIP] Atlas Contest - Yréas Kóltyn Village (Kingdom of Enía, Gold Coast region of Dóriant)
    You can always conceal the missing bends and corners with trees next time, of course, but this does look more natural now.
    One option for having a more "realistically" vegetated treehouse settlement would be to layer the canopy cover, and use map toggles to hide various of the layers as you descend through - including to show the forest floor as you have done this time, ultimately. This needn't be too complex, as a simple upper level of tree cover might be the only additional layer you'd need. That could hide everything, as it would be with a solid forest cover. Then toggle that top layer off to reveal the main houses and walkways (much as you have here), still with the missing walkway bends "hidden" by the next level down of the canopy trees.
    In terms of those bends, I haven't tried, but at this kind of overall map scale, you might get away with artificially shortening some of the walkway segments by using separate X and Y scaling for the symbols, and using each short symbol as one little part of an arc. You would have to overlap the part of the inner areas on the curves too, so again an experiment to try would be advisable first. It may not work, of course, and probably wouldn't once zoomed-in even a little, but it could be worth trying.
  • [WIP] 1000th Map Competition: Elkton, Alarius North Central
    There aren't any rivers marked on the area map. Should I take these out?
    Up to you, but I'd say not, since the place needs a reliable water source, and the area map is truly vast, so small streams and even modest rivers, likely wouldn't feature.
    And were-elks will the were-elks get a drink 😉?
    [What have I started...]
    LoopysueRoyal Scribe
    Not looking so steep to my eye yet, Sue. Maybe some contour-like slumping lines in the snow might help, and also some longer shadows for the trees on the steeper sections (only). It is tricky though, as maybe the houses will help the illusion - with garden/yard platforms, say.
  • [WIP] Order of the Fist Monastery
    It does sound like some kind of computer glitch, as I'm not sure what would simply wipe the sheet effects but leave other things on the map untouched.
    The textures going "soft/blurry" sounds as if it could be them showing as lower resolution than they should. That can be corrected by forcing the fills to have a fixed bitmap quality of "Very high", via the dialogue box opened by left-clicking the Display Speed Indicator icon, :CC2RESMODE:. Ordinarily, while that shouldn't be necessary, it does rarely need to be applied under normal circumstances.
    Beyond that, I think you'd need to share the FCW file here so our technical experts like Loopysue and Monsen can have a look at it and maybe troubleshoot the problems properly.
    MakeWayForJebus
  • WIP Community Atlas - Mortyn-Goya Confluence
    If you're stumped for ideas of what to place and where on a map, I'd suggest trying out some dice rolls on a few random overland design or encounter tables, if you have any. Even if you don't like what they come up with, that might spark ideas you do prefer - or variants on those themes.
    As I have the book sitting by me as I type this, have six random throws from the Shadowdark RPG overland generator tables:
    • A natural landmark controlled by a malevolent sorcerer.
    • A village occupied by a self-titled king.
    • Barrow mounds guarded by their current residents.
    • An abandoned, ruined, fortified keep.
    • A town connected to a large tomb.
    • A cave formation that's home to a religious cult.
    Make of those what you will!
    There are hosts of free-access tables online, often on blogs, although many are for rolling encounters, rather than places. Even so, you can still glean ideas from those. I came up with these three, of perhaps variable utility here, on a quick search just now:
    100 Overland Descriptors by Gnome Stew
    1d100 Random Events for Overland Traveling from Lore Wise Games
    The Collaborative Gamer's System for Creating Fantasy Adventures
    The last one has a whole series of tables, many of which won't be of much use here, but some of the later ones are readily adaptable for ideas such as you're asking for.
    Good luck!
    Shessar
  • Topographical map of the Ice bed of Antarctica
    Jim, there are currently 138 volcanoes claimed as known beneath the West Antarctic Ice Sheet alone. There are strongly suspected areas of volcanic activity beneath the East Antarctic Ice Sheet as well, but this region has been much less studied overall. The figure of 138 volcanoes is from Wikipedia's Geography of Antarctica page, an order of magnitude that other sources confirm at least. There are also numerous surface volcanoes on and around Antarctica, aside from places such as the famous Mount Erebus.
    The map(s) shown here are from the BEDMAP 2 survey project conducted by the British Antarctic Survey in recent years (you can access a much enlarged version of of the first map shown by WeathermanSweden on the linked page). It's also worth reviewing at least the first map (Fig 1) in a paper available for free PDF download via ResearchGate The glacial geomorphology of the Antarctic ice-sheet bed, because this shows both the current coastline (black outline) and the rebounded one Loopysue was talking about (white outline). The latter confirms Antarctica sans ice would indeed be a substantial "new" solid landmass to explore, along with some significant islands of many sizes across much of what's now called West Antarctica.
    JimPC.C. Charron
  • a prototype under ground home for a dragon and some questions
    So far as I can tell, there's nothing actually on the MAP BORDER sheet currently (apart from the usual automatically-generated pin items that retain a sheet in the map file).
    The brown frame for the map is on the cave floor1 sheet, however, as is the brown piece of flooring on the right side of the map, and I think this may be the problem. There is nothing else on that sheet, however.
    Hide all the sheets except cave floor1. That way you can move the brown frame to the MAP BORDER sheet, which will leave the patch of brown floor on cave floor1.
    It's always as well to remember to check the information lines on the CC3+ page when you have a symbol ready to place, to be sure which sheet and layer it'll be placed on. You can always change those before or after you place it, though if afterwards, remember to do so! I usually forget to check the layer, as this doesn't always change automatically with symbols...
    Also, when selecting anything, always keep an eye on the Command Line (lower left screen corner of the CC3+ window), just to make sure you haven't selected two things when you only wanted one. That's saved me any number of times, certainly.
  • Invisible entities outside of map on TEMPLATE layer
    What Sue said! (Beat me to it, Sue, as I was almost ready to post my own notes!)
    Plus, if you open one of the example maps from this CA28 style, you'll see there are seven such points on the TEMPLATE layer, so there'll probably be more lurking elsewhere on yours, probably behind what you've already drawn, in the area you didn't select.
    LoopysueRosemont_Line
  • Community Atlas 1000th Map Competition - The Winners
    Indeed yes, very well done to all our winners - and to everyone who took part, regardless of the results.
    Perhaps the most important achievement of all is the great contribution made to increasing the coverage of maps in the Atlas.
    Onward now to the Atlas Map 2,000 competition 😁!
    Royal ScribeLoopysue
