- Wyvern
- 3,240
- Member
- 5,519
- 24
WIP Ruins of Charn
@Don Anderson Jr. asked: The floors look a bit disheveled for some reason. Maybe someone can give some insight.???
As Helen suggested, the book makes clear the place is almost a ruin. Essentially, Charn's entire global population and all other life was destroyed in a single, momentary event a very long time ago, leaving just one living humanoid there (the person who caused it). The buildings are all pretty ruinous, as having been left quite unattended ever since, to the point where bits simply collapse if there are any louder sounds, and some have done so already, so there's rubble in places, etc. It's all looking pretty realistic to that currently.
[WIP] Sea Elves Outpost
Glad to be able to kelp a little ๐!
I'm not averse to hydrothermal vents myself, of course, if on a larger scale of mapping (so far).
WIP Ruins of Charn
I'm with Sue, in not seeing there's anything so very wrong with it overall.
Maybe a shadow effect under/near the table would help, and possibly separating each of the chairs/thrones a little. Less sure about this second point.
The bell does look a bit odd, so that might benefit from a minor rethink, and repurposing some symbols to help. A quick skim through the Perspectives 3 Bitmap B options suggests one of those open stone doorways (called "Doorway" in the Wall Features symbol catalogue) scaled-down, could work for the stand, and as a bell, maybe try one of the "Dish covered" symbols from the Bitmap B Furniture catalogue, though you might need to tweak the scaling a little, using slightly different X and Y scales to make it a little more vertically elongated.
You could then draw a suitable little line as the support rod for the bell (or probably two short lines, so it looks as if the support rod passes though the loop on top of the "bell". You could though perhaps resize and repurpose the "Quarterstaff" from the Weapons catalogue similarly for this instead. For the hammer, maybe try the "Maul" from the same Weapons catalogue.
ADDED EDIT: You might also think of using an alternative stone base for the bell instead of the table - perhaps the Bitmap B "Altar Nature", the "Altar Simple", one of the stone "Pillar Base" options, or perhaps that "Pedestal sm", all from the Temple and Statues catalogue.
Planet of those Apes
WIP: Nirmathas on Golarion
Only thing that occurs would be to make those little illustrative symbol discs for Tamran, Fort Ramgate and Lost Mines larger. It seems a shame not to better highlight those little pieces of artwork. And of course to maybe add more for other places too.
That might mean adding dot-markers for the places, and a line, or two lines, linking to the enlarged "art" view for the places, however, so you're still showing their precise locations, as well as illustrating them, though that may be more map-clutter than you'd prefer.
Community Atlas WIP - Panaur region of Doriant
I am open to further ideas. If it was my own world I would add whatever I feel, but being part of the community map. I am struggling a bit to enhance the map more.
As long as your ideas don't clash with/contradict anything that's been written about the continent and/or nearby areas already (see the map notes in the Atlas FCW files for those there are - not everyone adds some to their maps), and the overall details from larger-scale already-mapped areas aren't changed significantly, you're pretty much free to devise as you please. You could even devise some undersea mapped areas, if that appeals ๐!
isometric throne symbols
Importing Symbols from Other Mapping Programs
So long as the artwork is available in PNG format, you can use it to make symbols for CC3+ in the program. Whether the creators of the artwork will allow you to do this is something you'd need to investigate with each individual's licensing agreement under which you'd obtained the images. Most probably will be OK for personal use, but you couldn't rely on that assumption alone, especially if you were making maps to distribute or sell, for instance.
In terms of requesting custom symbols from specific artists, I can't comment for them of course, although I don't think Herwin Wielink makes such artwork any longer, having moved on to other projects.
WIP Ettinsmoor and northern Narnia
The main problem Sue is that part over to the west is simply blank, or hidden by a convenient piece of artwork, in all of Pauline Baynes' maps of the area.
There might be the option to add the coastline on the eastern side, as shown on her poster map, although that would be quite a bit of extra work, and would need everything moved west within the current map border. Might be worth considering though, if you felt up to the challenge Helen?
[WIP] Community Atlas - Eknapata Desert
Interesting, although there doesn't seem much more here than was already shown on the main Gold Coast map.
Might be worth adding a few more smaller features (dry valleys/wadis, rockier flat areas, dangerous soft or otherwise unusual sand areas, etc.), naming all the smaller settlements, and maybe naming the nomad tribes/trade routes suggested by the led camels too.
You should definitely add a scalebar.
Not sure if the labels mightn't be made clearer as well, perhaps using a smaller font size, so the place-name labels hide less of the "interesting" terrain.
Perhaps consider making the trails stand out a little better too, and maybe green-up the watercourse and lake edges everywhere more. The Nile creates a green valley surrounded by desert, for instance, so the active river and lake here should too.
