- Wyvern
- 3,240
- Member
- 5,519
- 24
[WIP] Community Atlas August Mapping Contest: Cloven House
Oops, forgot to mention that I found a small glitch with the fill styles in Dracula's Dossier. The "Floor, Roof S" (= roof tile south-facing) tool is using the west style's fill, so needs swapping out (the "Roof 270" style needs replacing with the "Roof 180" one when you have the Fill Style Properties window open, essentially).
As this map's so small in scale, I had quite a battle getting the fill styles rescaled correctly more generally, especially the cobbled flooring for the backyard, which has a "Fog" fill that overlies the cobbles, to make them look worn and damaged. The Fog was so dense, all it showed as was white until I'd scaled it down to something I felt sure would be too tiny to work!
And thanks Sue!
[WIP] August Competition - Vertshusen Town Hall and Tax Office
You should have stuck with the hall how it looked, Sue. It was perfect, and perfect for a very typical, ordinary day too. I've NEVER been in a neat waiting room in my life - and I've been in a lot of all different sorts, waiting and working!
As for all the political chat, you can make up whatever you wish, because that's exactly what folks do in RPGs! Game reality is whatever the person running the game says it is, after all!
More time today, and first-off, I checked the On New Macro as well as the On Open one, as I was fairly sure when I started the new file for this map, the Simple symbols set had indeed loaded. Which is where I discovered this was indeed the case, and that the correct CATALOG line should be :
@Symbols\Modern\Floorplans\Dracula Dossier\Simple.FSC
and not:
@Symbols\Modern\Floorplans\Dracula_Symbols.FSC.
The macro's easy enough to change in an existing map file drawn in this style using the edit facility. You can open it from the Drawing Properties icon on the top toolbar |CC2PRESETS| via "Settings - Map Notes", which brings up the "Select Note" pane.
Choose "OnNewMacro" and click "Edit", from where you can copy the last typed line with the correct location for the Dracula Dossier "Simple" symbols catalogue file.
Close the OnNewMacro without making any changes, and open the OnOpenMacro one the same way, then simply paste the copied text line over the last typed line there to correct it.
Before clicking "OK" to close the macro edit pane, make sure there is ONLY ONE BLANK LINE immediately below the typed line you've just replaced (try to move your cursor further down using the arrow key). If there is more than one, delete it, as if there's anything other than a single blank line there, the macro will become confused and sulk mightily at you! (That is, it won't work properly; note there MUST be one blank line there, however.)
Then save the file. You can check it's working by closing the file you've just saved and reopening it, where the 10 items in the Simple catalogue should now be showing in the symbols catalogue panel to the left of your drawing window in CC3+.
Forest Trail project - part 1
And another small map, this time in SS2 / CSUAC2
my quick ice bit CA189, not a cavern though
Yeah, I think it's a lack of the right Sheet Effects Jim. Try looking at the Winterbourne Langton sample FCW that comes with the Winter Village pack, and see how the narrow footpaths have been done there (on the ROADS Sheet). Those are a near analogue to what I was thinking of here.
For the final wolf tracks, however, you might need to be creative, and draw some suitable polygons to get the look right for footprints dragging through the snow at this scale, rather than using drawn lines. Try playing around with the Effects first though.
I can't offer a great deal more precisely, as the wolves are showing up as rectangular red Xs for me on the FCW. I thought I'd reloaded all this free stuff a while ago, but I got a number of red Xs on Quenten's Vertshusen city map for the recent mapping contest too, so I must have missed some stuff. I've never used these non-PF symbols though, so it's not really worthwhile my going through the involved rigmarole to try to load them all up again. Sorry!
Style Request: East Asian Floorplan/Dungeon
Smirnoff Castle
