- Wyvern
- 3,240
- Member
- 5,519
- 24
Community Atlas: The Vale, Panaur
There is an old text-file of the fonts available via a standard Win 10 installation plus those fonts that come with CC3+ and its numerous add-ons and in the Annuals, which is intended for use by Atlas map creators, although it hasn't been updated for some time (and I did run into a problem because of a duplicate font name for the "Mayan" font that came in the 2019 Annual, which I already had installed; so the list won't be infallible under such circumstances for others). The text file is available via this post from March 2018.
I have to admit, I now tend to list whatever fonts I've used in my Atlas maps as part of the Submission document for Remy, which makes it easier to spot if there could be a problem (I hope!). Plus it also serves as a reminder to me to check that text file to see what fonts are preferable to use.
Any Oriental style symbol sets out there? (CC3+)
Regarding the free monthly content, there's a new page on the PF website about this here. I'm not sure you can access it from any of the PF website links currently, but it was given on Ralf's recent blog posting about the new Orcish symbols.
From that new webpage:
This content is available as a separate download from your registration page (click the CC3+ downloads button to see it) and will be rolled into the full CC3+ setup and upgdates regularly.
It does seem that only the current month's set is available as a download directly (just July's content is available from my own registration page today, certainly), but I assume that downloading the full CC3+ package would include June's symbols now. That might become problematic if you forget to download the set one month, but perhaps it's smart enough to realise if you haven't yet downloaded a given month's set after the month ends?
If you've not found anything suitable for cherry blossom trees in an overland mapping style from Sue's suggestions, you might need to try a search for icons or mapping icons online to find something suitable in PNG format (or that you could convert to PNG, so you get a transparent background for the artwork), and either use that, or convert it into a CC3+ symbol using CC3+. A couple of quick Google searches using "oriental tree mapping icons" and "cherry blossom mapping icons" came up with quite a number of artwork options, certainly (all vector artwork, however, and often not in PNG format, but I was only doing a very quick chase-round!).
Can the "C" = corner option be added to the drawing tool options list?
Thanks for that. It was while watching Ralf having to add multiple clicks to get corners on a drawing tool smooth poly I was prompted to ask, but it's something I've run into repeatedly too when adding a smooth poly outside the map border to ensure the edge effects are properly hidden by the screen. Be nice to have a full set of such options with the smooth poly drawing tools, certainly.
Lighting Exclusions
That's what we like to see - people solving problems before we can leap in with the wrong explanation! ๐
Glows can be tricky beasts, I've found, which sometimes don't work well with other Effects even when they're on different Sheets on a map, and in variable ways (so they might affect some things on a Sheet but not others; I have no explanation for this...). Always worth experimenting though, to see what works best for what you want.
City of Nyxotos for the Community Atlas
For @DoubleDouble and anyone else interested, this page on ancient port structures has some notes on the archaeological/historical use of constructed breakwaters and other artificial port structures, beginning around 2600 BCE (Egypt, Gulf of Suez). I'd recommend taking time to check through the other links and references if this subject catches your attention, though your life can end up taken over by such matters without due care...
Mystara rather passed me by @Tonnichiwa, as I'd moved on to my own version of D&D, and other RPG systems, even by the time it first featured, as the Known World (in Module X1 "The Isle of Dread" according to online sources, in 1981). I have gone back in more recent times and looked over some of what was published for the Known World/Mystara setting, though after getting back strongly involved with D&D only when 5e appeared, I've concentrated more on finding past details for the Forgotten Realms setting, because of its intimate connection with 5e from the outset.
Yet Another Wargame Map set in ...
I suspect my (ongoing) connection to miniatures (and scenery, and everything else that goes with it) is because I started out as a model-maker, and only got involved in wargaming proper a few years after that, at the end of the '60s and early 1970s. Many tabletop rule systems are, and always were slow, but most of what I've done has been for my own interest and solo, so that was never a great issue for me. And a lot of the larger-area battles are fought using the miniatures as little more than markers, so I quite understand your "scale" problems.
I never understood why so many wargames have to be "balanced", when reality very rarely is (unless somebody's really screwed-up their reconnaissance and planning), which I think is why I never took to needing a group to game with. That was just too much like chess to me, whereas I wanted to try to better understand real, or potentially real, situations.
CA style development - "Darklands City" (issues for September and December 2021)
"A" looks more natural to me too, Sue.
The cross-hatched decoration (don't know what the proper term for it is, sorry!) seems undamaged despite the roof holes beneath it. As this seems to be of fairly flimsy outer surface material (compared with the depth of roof thatching), it seems unlikely it would have survived intact when the entire thatch below it has rotted away - even if it had just broken and raggedly partly fallen-in, say. I'd guess in some cases it might partly survive sort-of intact, but not always.
It does also look a little odd that none of the holes are where the greenery is; the extra weight and implication that that's where water's collecting, so mulching the thatch down into a growing medium plants can root into, might suggest that kind of area would be ripe for collapse as well.
Annual No 1, Issue no 8 - My example of the Spaceship style.
You could also have masts below the decks, from the base of the craft, though that depends if it needs to land or not, or horizontally out from the sides. There is a probable balance issue with masts only on the top - wind in the sails there will tend to tip the craft over end to end. Sailing ships rely on heavy friction with the sea, and their ballast plus keels to stay upright, but in the air, none of this is an option. Looks nice though, I know!
Magical engines would be more likely than combustion engines, I'd have thought. Combustion engines are just so incredibly inefficient, it's hard to believe those with access to magic wouldn't come up with something far better and more elegant.
As for propellers, the basic real-world concept derives from the Archimedes screw, c.200 BCE, so some bright Strompheian folks could have developed something similar for aerial use already, perhaps.
