3,240
Member
5,519
24
  • Panzer sample thread
    So far as I recall from modelling the 8- and 6-rad armoured cars (i.e. also from period images and information), the aerials were fixed in position, and at a height above the turrets all the time. These are the early-war "bedstead" frame aerial types, not the later war smaller "star antennae" which were retrofitted to some models, incidentally.
    Oh - and belated congratulations on your ascension to Master Mapper status @Lillhans ! Very well done!
    LillhansLizzy_Maracuja
  • Cartographer's Annual - all the issues linked in one place
    This really is invaluable, Sue. As I've printed-off the PDF mapping guides for virtually all the Annuals, I tend to remember if I've seen a given style somewhere, but if someone then asks, I end up hunting through the PF website pages to find it, usually guessing which year it's in first, because I can't find it in the mass of printouts otherwise...
    I've not explored anything like enough of the issues in detail to have favourites, though my ongoing Community Atlas mapping has provided opportunities to experiment with quite a few.
    @jmabbott If you're subscribed to the PF Newsletters, you'll find there are sometimes money-off vouchers available for webstore purchases in those, and the company has in the past run generous Black Friday promotions, which might make the complete Annual collection a bit less fearsomely-priced. It's how I completed my set a few years back; after that, it's "just" a question of keeping-up with it year by year. That's not so bad either, as if you're a subscriber, you usually get a time-limited, money-off renewal purchase option around the end of the current year as well.
    LoopysuejmabbottJimP
  • Live Mapping: New City Style (Part 1)
    I actually rather liked the look of the original map; there's a clarity to it that sometimes gets lost with the fancier non-vector styles. I may have made similar comments before though ๐Ÿ˜‰๐Ÿ˜!
    JimProflo1
  • Hotspot not working
    Glad we got that sorted at least! I did know about the hotspot disabling, but wasn't online after you replied yesterday. Thankfully, we always have Monsen ๐Ÿ˜!
    JimPScornado
  • Community Atlas: Embra - Enclosed Places
    Enclosed Place of Interest 3 is the Floating Dale Park:
    This can be used as a typical real-world park, with opportunities to wander around, or play outdoor games on the central Playing Fields, whose unusual shape may call to mind that Faerie outdoor games and sports may not be quite those familiar from the Mortal Realm.
    There are a handful of surface-level buildings scattered around the map's centre, as one of the map toggles will reveal:
    These include the Pavilion, where equipment for playing sports and games is available, as well as a restaurant in the central octagon beneath the building's dome. And yes, some of the vegetation is actually intended to be of living glass in Glass Tree Forest. And again yes, those ARE bridges made from rainbows over the River Clack. As ever, the text and PDF files will explain a little more about both facets, and others, from this map. In case this seems not very "Enclosed", there ARE boundaries to the Park which are deliberately less obvious than some.
    Loopysue[Deleted User]
  • Sinister Sewers - Style Development Thread (CA207)
    If the gelatinous cube symbol is actually partly transparent anyway (given you can see the texture of the floor below it), items don't all need adding to the cube. As long as the items exist as symbols, they can simply be put "below" the cube by the map's creator.
    On the size element, the "you can drive a cart along them" argument is partly why I suggested seeing the sewers in "The Third Man" movie, because that's where the climactic chase happens, with large numbers of police and soldiers, where there are multiple levels stacked over one another, and nobody has any problems for headroom, and places are up to river-cavern wide in parts. Somewhat like the early London Underground "tubes" (and I'd assume others built around the same time, later 19th century), some of these would have been dug out as trenches, had their surfaces coated with mud/bricks/concrete, etc., and then covered over later where necessary.
    LoopysueRoyal Scribe
  • SVG exports?
    Fractal Terrains can export as an SVG, apparently, BUT it's not available as standard, and it may not work properly. There's a trick to it, and caveats - see this Forum post by a certain J Slayton from 2022. Your safer bet though might be using an online converter from one or other of the CC3+ "Save as..." options instead, as Scott mentioned already.
    LoopysueScottA
  • Community Atlas: Embra - Hilly Places
    Thanks very much Sue!
    I wanted the cliffs here to look different to yours, which I'd already decided to use for the red sandstone types at Embra, as the Palace Heights ones are meant to be a harder, volcanic type of rock. Actually, a Faerie type of volcanic rock, which has different properties and abilities to "ordinary" volcanic rock, so I also wanted the forms here to act as a reminder that something a little different to normal was involved. I also used a similar style of cliff drawing in one of the Crossing Places Streets - the Rocky Vale under Seafield Road there, again because the Vale is a weird place that can't be reached, another reminder of something odd happening there.
    [Deleted User]Loopysue
  • Community Atlas: Temple of Nidag, Stormwatch, Emerald Crown Forest, Alarius
    Returning to the Stormwatch map, I copied the positions of the rooftop chimneys to a new BITMAP sheet in the Nidag Temple Surface map, so they'd appear above the wall lines, using simple purple squares:
    Since these only illustrate the rooftop flue outlets, the actual locations of the internal fireplaces can be a little different to this, and of course two fireplaces might even use the same flue, so allowing for some flexibility. Zooming-in to just the two buildings with the internal walls shows how I opted to set-up the fireplaces in these, based on where the purple squares were:
    This also provides a clearer view of exactly how the interiors were being set-up. All very basic still, with just the essential main structural elements.
    My initial aim with the interiors was to lay out just the access-points for the lower level dungeon design, as the next two snapshots illustrate:
    It's possible other properties may yet link with the subterranean places, because, as commonly, more ideas were forming regarding the general layout, beyond the vaguer ones I'd already had - such as the angled section containing parts of an inn-like structure, with separate rooming-houses, loosely mirroring the higher-class rooms of the underground directly beneath them. Surface houses too for some of the priests, to help keep up the pretence, as well as other houses for the ostensible religion's followers above the various underground areas, who wouldn't be reporting unusual sounds from below to the authorities, of course!
    Today's final shot shows that part of the area linking several properties has been dirt-paved, where there was once just a track, given that vegetation would be unlikely to long survive repeated foot-passage by priests and worshipful members of the Fellowship, aside from the relatively brief spring and summer at these northerly latitudes. Plus one more property has been "developed" with its initial internal fitments:
    And yes, this does mean another surface map level will be needed for the new upper storey to this property (and others to follow!).
    The thinking at present, incidentally, is that there'll be two priestly residences "above" the temple entrance ones (that's actually west, remembering north now lies to the right in this map view), and the new two-level building north of them will be a follower's house. In the angled segment, the only building with an interior thus far is a kitchen for both the surface inn and the subterranean kitchen, to disguise regular food deliveries below, and so forth. The long property below-right of the kitchen will be the dining hall/bar, and the rest of the properties along both sides of the track there will be other parts of the inn. These are not intended to be all connected, although some may be. Ideas are still developing...
    Not sure I shall get much more done next week, but I'll report back on progress at some point soon(ish), with luck.
    LoopysueMonsenzov66
  • Another little battle map
    Just a thought, but did you set up the trees so you can hide the canopies, yet still show where the trunks are for use in ground combat? Of course, that also means you can hide any GM-placed traps under the canopy cover as well ๐Ÿ˜‰!
    EdEJimP
