- Wyvern
- 3,238
- Member
- 5,515
- 24
Shout Out to Ralf
You'll find there's a lot of catching-up to do, I suspect, so good luck with that!
With the poll, I've never constructed actual languages for RPGs/mapping, though I've used bits of those others have done (or adapted them; Tolkien's the obvious, though not the only, one). What I have done more frequently is generate random names from tables, and then adapt those, tweaking the spelling/pronunciation quite often, and then giving the names a supposed meaning sometimes. Or sometimes just making up interesting-sounding words.
As for the Annuals, while I have all of them, I've used only a fraction of them for actual mapping so far, though I do try to go with new styles when I'm doing maps for the Community Atlas especially. I agree with Sue though, that they all have their uses under different conditions and settings, and deciding which one(s) to use for each specific map is an interesting challenge in itself. Not found one I deliberately keep going back to repeatedly, as I'm always a bit concerned I'll get stale doing that (likely that's just me though😉!).
OSR Dungeon Tiles - Quick Test
My Turn at a Parchment Map
Community Atlas: The Haunted Cloud Mesa Area of Kraken Island, Forlorn Archipelago
You're welcome, Jim (although it was decided for me by the dice!).
It has been a bit of a surprise during this little project so far to find that some places on Nibirum have been quite heavily mapped, others hardly at all. That does mean there's still plenty of scope for many other people to join in and add more maps in the less well-known places, of course 😁.
Community Atlas: Gruvrå's Mine, Serkbergen, Peredur
Actually, my description of how I organised where the maps were to go wasn't 100% accurate, as in one case, I DID actually use two dice-maps in the same place, Tlok-Pik in Nga-Whenuatoto, where the ruined above-ground temple dice design seemed to have been deliberately drawn to fit the subterranean map I'd already rolled-up. That was too good an opportunity to miss, I felt. Which is ever the way with randomness in such things - it should never get in the way of what you find interesting!
Community Atlas - Forlorn archipelago - The Bleakness, 2 villages and 2 keeps
Annual Issue 15 - Heraldry Symbols
Yes, the charges are vector symbols, with many nodes. There are also multiple entities in every symbol - lines and polygons - and the symbols are set up to go onto multiple sheets too. That does all make things run slower than normal, as the symbol is redrawn after every movement of the mouse. Irritating, but just how it is, unfortunately.
City of Nyxotos for the Community Atlas
Sorry, Frosty, I don't.
However, a quick check online shows there are at least two CC3+ maps of the Isle out there, both from 2022. One is by Jason Hibdon, on the Atlas of Mystara website, the other is on the Talaraska blog. In neither case is there an FCW file provided, but it couldn't hurt to contact the people involved and ask nicely!
I'm not sure if either may be on this Forum, or perhaps the Cartographer's Guild, as well.
Live Mapping: Parchment City (Second Try)
