3,238
Member
5,516
24
  • And like a bad penny, I keep showing back up!
    Oh yeah, 'cos finding and installing the programs again - and the Update last of all (don't forget the Update!!!) - is only the START of the process...πŸ’»οΈπŸ–±οΈπŸ˜‘πŸ€¬πŸ˜΅πŸ”¨ο»ΏπŸ—ΊοΈο»ΏπŸ˜
  • Stop teasing us Ralf !! :)
    Yes, I can confirm the e-mail reached me too, timed at 19:57 UTC on November 19. Unless that was sent as a separate, second tranche of messages because of the comments here (and I imagine more directly too), it still seems like something worth investigating to see what went wrong, so it (hopefully - computers & Internet, after all...) doesn't happen again. Well, not till next time anyway πŸ˜‰
  • Looking for Advice on Terrain Techniques
    Yes, the Trace command only works with Drawing Tools (the formal name for what you're calling "terrain tools"; your "drawing tools" are, slightly confusingly, known as Draw Tools - these are the simple lines and shapes), so you need to create a new Drawing Tool if you want to use the command, and the Drawing Tool currently doesn't exist.
  • City of Torlok
    D'you think he knows there's a giant skull monster trying to eat his head? πŸ˜‰
    The gold staff doesn't look quite right though. It seems as if it's behind his hand, not in it. Might be worth checking to see which sheet the staff's on, as if it's the staff version with the hand cutout, it should fit to look as if it's being gripped correctly.
  • Community Atlas: Errynor Map 33 - Siolforland
  • CSUAC Symbol Pack
    Yes there are. They're in their own sub-folder labelled "Scorpions" in a standard (however complex - CSUAC, after all...) installation.
    jmabbott
  • Forest Trail project - part 2
    Tempted to say "cliff and the shadows" here, but that probably just dates me (and will likely prove too obscure for the youngsters hereabouts...) πŸ˜‰πŸŽ€πŸŽΈ
    Moving swiftly on - well done, Sue! 😁
  • Community Atlas: Dendorlig Hall - A Sort-Of D23 Dungeon for Nibirum
    Sounds like a plan, Monsen! Checking the Atlas maps and notes, would I need to connect it to Scott's "Darklands" as well? I'm a little hazy as to how far underground those might be, though there are a couple of small chasms already in this "Blue" that could be loosely claimed as descending far enough, without needing specific inter-map links - that by label 168 and in chamber 295 for instance (which latter could be converted to a chasm instead of a rocky cave wall - the original hand-drawn feature there was rather ambiguous).
    Well, it just fits better to how the Dendorlig region is set-up actually Sue (as the GM would say anyway, of course... πŸ˜‰πŸ˜ˆ).
    Thanks @Autumn Getty, and good luck @roflo1!
    The final FCW file for the Atlas is going to be a bit different to the image here for this dungeon, as I've started making alterations to fit how I see it as being Dendorlig Hall, rather than a generic random dungeon as shown so far. Not least is the map's probably going to be inverted, so what's currently shown as north will be more southeast, to fit better to the area map (the cardinal directions will be roughly those suggested by the corner "arrow"-shapes of Room 17, for instance; at least on current thinking!).
    As the random design created a lot of oddly small rooms and buildings (?) in a cave in the current map's top right, and drawing on the map notes for Malajuri, I'm thinking this part is a gnome settlement under King Dendorlig XXX, which has only recently been reoccupied, with much of the dungeon remaining little to unexplored. Thus the gnomes might be looking for cannon fodder adventurers to explore and map further for them. What's more distant from that top right corner remains a little vague in mind currently, however!
    Actual mapping progress has been delayed by other matters, however, not least events yesterday relating to the first paragraph in my initial posting here (yes, it's all still dragging interminably on, like slaying a dragon that has far too many hit points...).
    More when I know what it is (on the mapping and dungeon notes only!!!).
    roflo1
