- Wyvern
- 3,238
- Member
- 5,516
- 24
Latest Update Won't Download
Glad you managed to sort this out Scott. I found the download speed was VERY variable yesterday evening when I picked-up the latest CC3+ Update (about 4 hours before your own attempt, from the time-stamp on your first post). Initially Windows "estimated" 20 minutes, which then rapidly increased to over an hour, before dropping back sharply after a few minutes. It actually downloaded in under ten minutes in the end. Seems likely there were some oddities ongoing all over, however.
This afternoon here, I had my connection drop-out entirely for no obvious reason at all about 90 minutes ago. It does this from time to time, which I assume is something fairly local, though actually, it hadn't done it since last November till today.
The Creepy Crypt project
Light Harbour - a coded city
A couple of issues with the text in the close-up shots, where the "text acne" effect is happening to cause the contour lines to bleed through the lettering. You should be able to cure it by changing all the text's colouring to something slightly different to whatever the contour line colours are (or ditto the contour lines vs. the text if that'll be easier).
Also, are there really so many separate "Basilica Squares"? Seems unhelpfully confusing, and I can't imagine the locals wouldn't change the names very quickly to something more memorable for each one.
Community Atlas - Forlorn Archipelago - Fisher Isle, several villages and surrounding areas
Community Atlas: Embra - Travelling Places
Thanks very much @Monsen!
You're doing well to get things done this quickly; I imagine this will be one of your busiest times of year for non-PF matters, coming up on the end of the academic year and suchlike.
Plus I know you have more than just my maps to place in the Atlas currently!
Scaling Bitmap Fills
Debris on the lower floors looks a little flat; as if it's part of the floor itself, not sitting on it.
Also, if the structure is stone, the fractured edges look odd. Generally, if damaged, you'd expect entire stones to drop out, or parts of individual stones, as well as leaving surface damage to those that survive. The very fiddly raggy edges that cut slightly into neighbouring stones and wander across others look very unnatural. Right now it looks very like the floors are made of thin sheets of acetone-melted expanded polystyrene.
That impression is also reinforced by the lack of stone debris on the floors below; it just seems to have vanished.
You might want to tweak the shadows on the upstanding parts of the battlements; it's strange to have the same length of shadows from them on the ground as on the roof, as if the roof's floor is actually level with the grassy surface, and the tower's interior is really below ground.
Island Chain annual
I can confirm the problem Quenten reported. At a guess, it may be to do with the CA187_MediumIslandChain.esc file (I'm not familiar with the file type, so don't know what to open it with to check). That's the file being accessed by the macro that runs the drawing tool, at least, and it seems to be the main difference between the three Island Chain drawing tools from a quick look.
Also, can you make your own island shapes and add them in - if so, how do you add them
You can just use one of the basic landmass drawing tools in the style to do this. Note you can also delete individual islands and replace them this way (as I just did a quick test doing precisely that).
Contours and terrain problems ("decide settings myself")
