- Wyvern
- 3,238
- Member
- 5,516
- 24
Global Lighting Not Working
Winter Village style development (March 2022 CA issue)
Wet medley and a city!
Hadn't come across the Branconia RPG before (there's a lot of RPGs I haven't - so many RPGs, so little time...). I see it describes itself as "Spaghetti Fantasy", and I'd recommend a quick review of the short video on any of the DTRPG pages off AleD's link in the first posting here - Ennio Morricone-ish music meets Italian Fantasy gaming!
CC3+ Basic Vector Map
WIP: region of Lilia
It does also depend what sort of effect you're looking for. If you want to make it look like a boundary line, for instance, you might try a polygon with an Edge Fade, Inner effect on its sheet, and adjust that till it looks right. Or you could try adding a Glow effect to the various symbols involved, if they're actually the key things (though it sounds more as if it's the whole region you're wanting to highlight).
Best advice would probably be to keep experimenting and thinking about what you'd prefer to see; playing around with the options in the CC3+ effects is never time wasted, even if you can't get quite to where you'd originally thought you might!
Monasteries
Ravenford
Clearly a delightful spot; very tempting for a dragon...๐
If you have it, you might be interested in trying out the sketchy contour line symbols in the Black & White Towns CA issue from 2015, which are similar in appearance to those in your castle hill lines (though naturally, you'd need to add your own background colouring for those, as B&W only).
The Creepy Crypt project
Searching for Farmland
You're most welcome Alan!
You could of course just add the RGB Matrix Process Effect to the Sheet the farmland is on, if you'd prefer, rather than the whole map, which may or may not help (possibly not though in this case). You could try a different colour than white for your background alternatively - a pale grey, perhaps, or another colour that will work better under the whole-map RGB Matrix Process greyscale colouring, perhaps something closer to the usual farmland colouring instead.
If you want to look further into the options the RGB Matrix Process can generate, you may find it helpful to read through this PF Blog posting by one of our true resident experts, Remy Monsen (he wrote the Tome of Ultimate Mapping, so this is no idle remark!), where he explores this Effect in greater detail. It is very much trial and error to get it to do what you need once you step off the path of the available presets, but it's also worth doing, as you can never tell what marvels you may accidentally turn up.
