Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
JPG Fill Different from Editor
This happens if the fill style doesn't have a specified scale in the fill style dialog.
Just open the Fill style dialog (FS: in top right), go to the bitmap files tab, find your fill in the dropdown, enable the scaled checkbox and provide appropriate values for the scale. Some experimentation may be needed.
Once a fill is scaled, it should always fill the same area no matter the zoom or export level.
Community Atlas 1000th Map Competition - The Winners
Finally was able to process a few more maps. This time, it is the contributions from @cyrion , @Quayuazue and @Mathieu Gans .
Thanks for contributing.
HELP - My houses are a single color block, still pretty new
Your buildings have entities on the wrong layer. This is probably caused to how the random building/street command works. The correct layer is set when the symbol catalog is loaded, so if it changes after that, it can cause issues with this command. It can be worth checking that the correct layer is set every so often.
Fortunately, it is easy to fix.
To fix it for future placements, simply change the layer shown in the status bar to one of the city demographics layers; the ones named BLDNG (XXX).
To fix buildings already placed in the map, either simply delete and recreate them, or use the Change House Layer command found in the City menu on them. Note that after selecting the buildings and Do It, the command line will prompt for a layer. the easiest is to right click inside the map to get the layer dialog, then pick the appropriate demographic layer, hit OK, and when back in the map, hit the refresh button to update the display to actually see the change.
CD3: Advanced Street Settings
The only way is really to just load them up in the house style editor [HOUSEOPT] and look at them one by one.
To quickly look through them without clicking yourself to death, take advantage of the fact that Windows GUI components are keyboard friendly. Simply use the top dropdown and click on the very first style in the list to select it and collapse the list, then as long as you don't click any other controls, it will be the active control, and you can go through the styles using the arrow keys.
[WIP] Community Atlas: Snakeden Swamp, Lizard Isle, Alarius - Dedicated to JimP
Community Atlas - North West Berenur - Azin Forest
These maps are now in the atlas. Thanks @Ricko Hasche for another excellent contribution.
Note that the Adill, Reefs and Uldir was wrongly scaled, they were about twice as large as the corresponding area on the parent map, so I re-scaled them and edited the scale bars.
Floorplans and City Designer 3
The hyperlink consists of 2 entities, the link itself (Which is normally invisible when you load the map, make it visible by View -> Show Hyperlinks), and a purple rectangle which just shows where the hyperlink is.
Both of these can be deleted by the regular erase command, BUT the HYPERLINK layer may be frozen, in which case you need to thaw it before you can erase it.
Also note that they should also both be on the LINKS sheet, so you can also just hide (or delete) that sheet.
Using Color Palettes
Importing landmasses from images
I would love to know if I can import my old maps as an overlay or better yet, for CC3+ to generate landmasses from my images.
You can insert an image into your map using Draw -> Insert file. You can then either place this on a sheet below the one you draw on, or add a transparency effect to the sheet holding the image if you wish to have it as an overlay.
CC3+ has a command called TRACED than can construct an entity from an image automatically, but this works best if the image is black landmasses/transparent seas, and it will only be able to handle the outline, it can't really do inland contours and things like that (unless you are able to extract those manually as a separate image to be processed.)
can I make detailed regional maps from a bigger one in CC3+ without having to make a new project and trying to get the coastlines match? Meaning, is there a way to select a zone of the map and tell CC3+ to make a new project based on that?
Yes. There are a couple of ways to go about that. All the options do require some manual work to get a good end result, but getting the coastlines is quite simple (Although you do probably want to add additional detail to a zoomed in part of the world). See here for one way to do it
Community Atlas - Haddmark - Peredur
Thanks for another great set of maps @Ricko Hasche. You've put us across the 700 maps milestone with those.
