Monsen
Monsen
Monsen
660
Administrator
8,858
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Community Atlas: The Hall of the Seer, Glaciär Kristol, Ezrute
    Fixed. Turned out you had been a bad boy. There was an apostrophe in the map filename, but not in the pdf one.....
    Don Anderson Jr.
  • Community Atlas: Lonely lighthouse environs - fisher island - fonlorn arquipelago
    Yes, as I wrote above I skipped that map because it seems to be the wrong version of the fcw in the post.
    Ricko
  • Upgrading old CC2 maps
    In most cases, CC2 files can just be loaded straight into CC3+ and they should work. There is one big breaking change though, in CC2, everything on the Common sheet (these are actually things that are not on a sheet at all) displayed on top of everything else, but now these goes in the background.
    There is a CC2 to CC3 converter in the File menu, but in this case, unless you want to do more work with them, it may actually be better to skip that, and instead just make a new sheet, then move every entity that is on Common to this new sheet, and make sure it is at the bottom of the list of sheets. This should ensure the file look the same as it did in CC2.
    Now, looking at those images (I looked at wholeworld and Karameikos), it does seem like they have been post-processed to add a more textured feel. I can't find any indication in the .fcw's that this texture came from there, neither does it look like CC2 texturing (although I might be wrong). Obviously, replicating that exactly will be tricky, but there are many things that can be done in CC3+ to maybe approach a similar feel if that is what you are after.
    The maps have also been drawn with zero-width lines, which was common for these old maps. The issue with that is that the lines will always export as thin as possible (1 pixel wide), so when exporting in higher resolution, this will also make the lines appear thinner compared to those old exports. So here, they should probably be given a proper width instead.
    All of this will require some work processing those maps.
    Fonts are not embedded into the map files, but as long as you have the right fonts installed on your computer, these should be used to provide the right look here. You can always inspect a text entity and see what font it is set up to use if you use the List command from the Info menu on them.
    I am not sure exactly where you want to go from here, so I just leave this as a small introduction for now. Let us know if you need help with any of this and we'll happily provide more detailed instructions, or if there is anything else you are thinking about when you say the maps doesn't look like the images.
    Thorf
    The whole world file has turned out rather nicely, although I was unable to change the line widths successfully. When I tried to do this, the shapes turned into filled lines.
    Yea, you can't just change line widths of polygons. A polygon is filled as long as it is set to line with 0, otherwise it becomes a hollow shape with the outline the size of the line width. To have a thick outline on a polygon, it needs to be a separate entity. It is quite possible your polys already have those, if so, be sure to only select the outline and not both the poly and the outline when changing width.
    As for the colors in the maps, it looks like the original maps was made using a different color palette. In the CC2 days, you could have a different palette by having the palette stored as fcw32.pal in your CC2 installation directory, and all maps would then use that palette instead. So you probably need to go see if you can find that original pal file somewhere.
    Since that file affected all maps loaded, we don't usually do that any more. These days, you can attach a palette to a drawing, and the drawing will use the embedded palette instead of the default one, which is what you should be doing to these maps, but you'll need to find the old palette if you wish to know the exact colors used, otherwise you just have to guess and experiment.
    Thorf
  • Importing the water tool from another map's style
    You can just pick a different drawing styles from the :CC2DRAWTOOLS: window.
    But you will need to import the fills first, have a look at this FAQ topic.
    Don Anderson Jr.
  • Community Atlas - Fonlorn Archipelago - Bleakness - Death Forest.
    That's a shame. But it is is up to you if you want to remake it or not, nothing else in the atlas depends on it, so everything else still works fine.
    Ricko
  • Community Atlas: Aenos Isle North, Demosthenes Swamp, Artemisia
    hmm.. Thought I extracted all those pdf files. Maybe I put it in the wrong folder somewhere. Fixed now anyway....
  • The adventures of Jack
    No, I can't do art even if the life of everyone on Earth depended on it. It's done by one of the artists for the book, but I don't know who, the artists aren't credited per image.
    Don Anderson Jr.
  • Repaired installation results in Invalid licence message
    That's best solved by contacting technical support through the form on your registered user pages.
    Perrorist
  • Community Atlas: Kara's Vale, Ethra, Doriant
    Fixed now.
