Monsen
Monsen
Monsen
660
Administrator
8,858
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Community Atlas - Irisian City States - Giant Circle Island
  • Font Question
    There is a list of fonts on the FAQ page for the atlas, but it is quite a bit outdated by now. I don't know of any other lists.
    As for license questions, those are best sent straight to ProFantasy
    Ricko
  • Hardin - Folortalin - Zaraogra Island
    I get your point, but if this is a female dominated world where they are the stronger ones, wouldn't they want their own female titles that show that they are a female, the strong sex? Why let a mere male use the same title as them?
    Don Anderson Jr.
  • Can vector symbols be imported?
    Unfortunately, while "vector artwork" is a generic term, it is generally not compatible across different programs. The name vector really just means that the artwork is represented as mathematical coordinates so that it can easily be calculated at any size and transformation, but the similarities end there. Every program have their own features that they can apply to the vector artwork, and those features naturally only work in the source program. So even if you could import vector artwork from inkscape, you would still lose all the features of the artwork that inkscape supports that CC3+ doesn't Generally, this means that making vector artwork in an external program isn't really going to do anything for you, just make it in CC3+ directly instead. If you can't do what you want in CC3+, then that feature wouldn't have worked when importing the artwork anyway. When going cross-application the raster formats (png) are generally your best option, while they lack the scaleability vector atwork has, they look the same everywhere because their cintent isn't computer locally.
    As for the FSC format, that is the fastcad file format, which is what CC3+ builds on. I don't think any program but fastcad uses this format, and there is no advantage to making them in fastcad over doing it directly in CC3+, the tools are basically the same anyway.
    CC3+ can import (older) autocad files, which many programs support exporting to. This is the main option for importing vector artwork, but all the caveats from above still applies, most of the features that another program like inkscape can offer won't survive the transfer.
    CC3+ also have some work in progress support fro importing SVG files, which is a popular vector format used by a lot of other software, but again, it is subject to the same restrictions as I discussed above.
    Royal Scribe
  • Community Atlas Project - Download information - Contributions Welcome
    No, that's fine, but you shouldn't grab the navigation bar from an existing map. I customize that thing for every map. Just make your map normally without it. I'll add it myself when I process the map for inclusion into the atlas.
    Copied from the main map, then had to resize so the scale is correct.
    That sounds a bit weird to me. Since the scale is already correct in the source map, no resizing should be required. (Unless you are talking about the resizing the map border, since the map area of the original map would be way to large to just map a small portion.)
    Kevin
  • [WIP] Community Atlas - Gold Coast, Doriant
    What did I miss that should be named?
    Everything can be named of course, but I feel that huge plain between the desert and the coastal ares deserves a name. It is such a prominent feature. The rest of the mountain ranges, hills and forests would also love a name.
    In the future, would be better to post the larger map in my galleries so that folks can zoom in?
    If you want people to freely look around the map and zoom in where they want, the gallery is a better option, but if there are specific places you wish to highlight, it may be better to post those views in the post like this. But you'll always have the option of doing both as well.
    Royal Scribe
  • Long Time Mapper, First Time Poster
    Welcome to the community. Looking forward to seeing your maps, and remember, we're always here to help.
    Ptarmigan
    You can have as much time as you need. The only thing I want is that if you spend more than 6 months that you tell me that you are still working on it. This is so I can delete stale reservations that people have abandoned, but as long as people have a desire to finish their reservation, I don't mind if you do it in 1 day, or take 5 years. Contributing to the atlas should be fun, not having to stress out about deadlines.
  • Cartographer's Annuals and content
    All annuals have their own set of pages with description of each issue, including a image gallery. You can access these from the Products menu on the main profantasy website. Here is thew link to the 2007 annual, there are links tot he rest from that one.
    Kevin
  • Community Atlas - Kumarikandam - Northwestern Tolgad
    Added to the atlas now. Thanks.
    Royal Scribe
