Monsen
Monsen
Monsen
660
Administrator
8,858
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Error Message with Ancient Tombs Isometric Map Style
    I don't think you actually need Perspectives to take advantage of the issue itself, since it comes with proper symbols for both walls and floors. But you need it to use the 3D projection command, and it also gives the advantage that you can draw additional isometric shapes manually.
    Talaraskan
  • XP Programming
    Yea, messing up your map is kind of easy when you are given direct access to the raw data. Part of the fun :)
  • Annual Ancient realms + Local Area Maps + Mike Schley Valley Landscape
    Looks nice, but I am not sold on the fields here. They look a bit out of place.
    JulianDracos
  • Chart question
    Not sure exactly how his setup is, but it looks like he's just added two filled polygons to a sheet that is on top of everything else, and then added text and decorative symbols on top of that again. Probably 3 or 4 custom sheets. (background, text, symbols, border)
    Ricko
  • Community Atlas - Doriant - Galahais - The Morstarik
    Roads look much better now, really makes a huge difference when you are not seeing part of the road inside the marker circle, but the two medium cities between the red lables in the middle of the map still looks like they could need the same treatment as the rest.
    You've got a spelling error, a semicolon has snuck it's way into the Wizard-realm.
    The red dotted line actually goes on top of the floating island symbol at A. This looks slightly weird.
    Text is much easier to read now, but I still find 'C' and to a certain degree 'A' a bit hard yet. They could do with a more powerful glow.
  • I want to uninstall CC3+, I cant
    Contact technical support using the form on your registered user pages. They'll sort you out.
    Juanito Pecados
  • Copying from one map to another
    Make sure you actually finish the copy command. The most common mistake here is that after selecting the entities to copy, people don't realize that CC3 is now asking for the copy origin. If you fail to do this, the selection is never copied to the clipboard. Always keep an eye on the command line, it tells you what CC3 is expecting from you at any given time.
    Chanticrow
  • Forgotten Realms Interactive Atlas repairs.
    Well, they are doing a good job of telling what the problem is and how to fix it for anyone interested in giving their own install a touch-up. Anyone who owns the atlas product can follow these instructions. They can't share the actual maps for copyright reasons, so this is a great second-best resource for fixing things yourself.
    Because it is useful to several people. This thread allows the participants to discuss and give input on their work and share their findings. Discussing ProFantasy products (and what you can make with them) is the main purpose of this forum, and while not in sale anymore, the FR Atlas is still a ProFantasy product, still used by a lot of people, making this the ideal place to have this discussion. Not all discussions have to be relevant to every forum member for them to be valuable.
  • How do I turn off auto-rotate of buildings?
    Just turn off Smart tracking. It's available from the symbol options dialog you get when right clicking in the map when in the process of placing a symbol.
    You can also optionally completely disable the smart symbols from the same dialog.
    Don Anderson Jr.
