Monsen
Monsen
- Monsen
- 660
- Administrator
- 8,858
- May 14, 1976
- Bergen, Norway
- Website
- https://atlas.monsen.cc
- Real Name
- Remy Monsen
- 27
Annual 1, issue 2 - John Speed map. My example after the Live Mapping session
Greetings
First Map
Community Atlas-Elen Daelarion-The Mithlas Holes, 8
The Sunken Temple
@Quenten wrote:
Now you need to find a location in the Atlas to place it - plenty of lakes to choose from.
I am not even sure it need to go into a lake in the atlas. Honestly, it looks a bit more like a saltwater map, so I might just put it off a coast somewhere.
WIP - Quay thing
The Land of Vareltia, My First Map!
Looks good. Your varied mountain sizes came out quite nice. Not sure you're doing the map any favor with those number labels instead of proper labels though.
Would also be nice if you put a copy of your map in the post itself, so one doesn't have to click a link to see it. (And I know by experience that people keep cleaning up and removing things from image sites (Perhaps because a new version was uploaded), leaving the links dead)
Too early for a CC4 wishlist thread, or is it timely?
@efenord wrote:
Where I can get a list of those commands?
Most of the commands are available in the help file, although admittedly, it hasn't ben updated with the newest commands added in later updates.
If you have the Tome of Ultimate mapping, it comes with a full command list, both in the book itself, and as a spreadsheet for easier search/filtering.
Is there a discord? Also struggling with this awful controls, especially when it comes to floors
You can find the coordinates of any entity by using Info -> List on it. But if you use 0,0 as I wrote above both for the origin point during the copy and when you pasting it, you don't need to know the actual coordinates, since what you are basically doing is copying and pasting it with the same offset without caring exactly what that might be.
CC3+ isn't the easiest or most intuitive program out there, I'll give you that. It does require a little effort to learn properly, but once you have the understanding of how it works it is far more powerful and you can to much more advanced stuff than in those simple 2-click programs. But that power comes with a cost of being a bit harder to learn. I won't be arguing against you calling the GUI old fashioned either. But most of the rest of what you wrote is either directly wrong or easily changeable, or happen for good reasons:
Like seriously, you need to press Refresh when you place an object down that's around floors.
I understand why the refresh can be weird, but it is for performance reasons. CC3+ isn't a bitmap editor like Photoshop, and a CC3+ map contains thousands of entities that need to rendered for every screen update. In Photoshop, you just have a grid of pixels (one per layer). You can have things like vector objects and such in PS too, but not the same amount. Everything being an entity you can manipulate has a huge advantage when editing your drawing, but yes, it does come with a performance cost. Not automatically redrawing the screen for every minor edit is the way to offset that.
You need to manually edit the layers because you placed things wrong, instead of it being automatic (when will a mountain ever be in front of trees?)
CC3+ adds things to the correct sheet (equivalent to layers in Photoshop, named sheets instead of layers because CC had layers long before image editors, so they were named sheets to avoid changing existing terminology. In CC3+, layers are just a grouping mechanic, use sheets whenever you would use layers in photoshop) automatically. Exactly how they are added depend on each individual drawing style, some have mountains on one sheet and trees on another, some place them on the same. This isn't decided by the program globally, but by the style. And yes, you may absolutely want to place a mountain in front of a tree, or partially anyway, to let the top of the tree stick up behind the mountain side. Generally, a single run of sort symbols in map fixes any ordering issues you may have.
autosave is literally a button prompt
The autosave prompt is a bit annoying, but you can turn off the propmt form the autosave options and just have it save automatically in the background instead of bothering you.
It's choppy and laggy for when you pan around the canvas, laggier than photoshop. When you delete objects, there's a white square that needs a refresh.
These things are for the same reason as mentioned above under refresh. White square goes away whenever you zoom/scroll the map as well as when you hit refresh, it is just a temporary artifact.
With doors and walls, why not have it so the door automatically connects to the wall and deletes the segment of the wall underneath it?
They do. Again, this is a property controlled by the style, but most dungeon styles have doors and windows that align to the wall, and cut it.
Why not add brush and scatter options for creating forests instead of clicking, dragging?
Wouldn't mind a brush, but for forests and random symbols in an area, you have the Fill with Symbols and Symbols in Area commands. Most overland styles have forest drawing tools that uses these commands to fill the area you define with trees.
If you click on another window and drag the CC+ Window, there will be floating text where it thinks your mouse was.
True, the floating prompt can get temporary stuck until you move the mouse inside the CC3+ window again. Note that if you wish to get completely rid of it, you can turn it off from the program options.
There's no blank tool option, where it doesn't do anything if you click.
Not sure why you would need this? You can't do anything with the drawing without a command anyway, so that would basically just be ignoring your clicks. CC3+ repeats the previous command when you click without selecting a new command, because that's what you usually want to do. If you really want a blank command, CC3+ has one though, but it is not on the toolbars or menus, because it isn't normally needed, but you can activate it by typing NULL and hitting enter on the command line.
There are no resizing bars, instead, you need to type it in manually.
True. I know many would love to have these. But you don't need to type in things unless you want, when you use for example the sclae command on an entity, it is resized just by moving your mouse up/down so you can eyeball the size. Typing is good when you want exact values and high precision though.
You can't move layers up and down or overlayed or change the opacity.
You can, but as I said above, in CC3+ these are the sheets. Sheets can be reordered at will, and you can add effects such as transparency to them to change their opacity.
Why are there two colour selectors? Why not just one? They're exactly the same.
How are they the same? You have the color bar on the left hand side which gives quick access to a subset of colors, and then the color indicator on the main status bar which you can click to bring up the full color dialog.
The manual still uses Windows 95 (that's older than I am), why?
Where did you get that manual from? It certainly isn't the one provided with the program. The CC3+ manual doesn't really address operating systems because that's irrelevant, but every screenshot in the manual is from CC3+ running on Windows 10.
