Monsen
Monsen
Monsen
661
Administrator
8,864
Birthday
May 14, 1976
Bergen, Norway
Website
https://atlas.monsen.cc
Real Name
Remy Monsen
27
  • Is it possible to send an RCV20 command from an XP to the "main program"?
    Won't help you now that you got it working, but I should probably put this into a blog article for future users.
  • Small white dots on buildings when exporting city maps to PNG
    Well, there are a few less entities, so it would be marginally faster, but in practice, nothing you would notice.
    Aldebert
    Thanks.
    I developed that template under VS19, which is why it probably requires it by default, but it doesn't really take advantage of any new features or anything.
    Technically, there is no reason at all to use VS19 for XP development, but it happened to be ready for release at about the same time as my first blog article, so I decided to use that, since that was the version people would find at the MS download site. I actually wrote the blog article while using the beta version, and released it on the same day VS19 was released.
  • Commission WIP
    Hmm, that looks a lot better in CC3+...
    If things look different inside CC3+ when compared to an export, that is usually a fill or effect scaling issue. If fills are not scaled, or if effects are scaled to view size, the output will be different since the "view" during an export is very different from the normal view.
    Size of the export (in pixels) also matters a bit of course.
    jmabbott
  • borders on symbols - a 'rookie' question
    Looks like the regular selection indicators. As long as you are not inside an actual command and actively have these selected, it should go away with a click on :CC2REDRAW:, or in very rare cases, select something else first, such as draw a temporary line, then :CC2ERASE: it (since this involves selecting it) and then do :CC2REDRAW:.
  • 1st maps with cc3+/dd3
    Nicely done. These are good maps. That road in the top map looks like it could be improved with a bit of an edge fade though, or something else to break up that very hard edge.
    simianorganism
  • Converting old CC-DOS maps to CC3+
    @Thorf wrote
    Would you be able to export the rest of the set to PNG from CC-DOS?
    Sure. What resolution do you want them exported in? The ones in the forum where exported in 2000 x 1500, the ones in the gallery 8000 x 6000
    @Loopysue wrote:
    Is this a style we can still use in CC3+ to make new maps?
    Yes. It is not defined as a style in CC3+, but the symbols are all there, and the rest is just (fractal) lines.
  • October challenge: Bow of Promises (Street) WIP
    Nice. Is the place as happy as the color scheme infers, or are there some dark intrigue hiding in the shadows here?
    WeathermanSweden
  • Problems using Cos3 Deckplan Bitmap style
    I get the 'zoomed far out' behavior (looks like the zoom is set to fit the default 1000x800 map size, and don't zoom in automatically to the smaller template), but not any other issues.
    You'll probably be able to fix it by editing the actual template itself, set a snap grid there and save it.
    DaishoChikara
  • Supplemental to Humble Bundle
    Works perfectly fine for me too. And I checked the source code of the website, the link is as a plain standard link as they gets, no fancy javascript or popups or confirmations or anything weird that could potentially fail, it is just a link straight to the file.
    I would recommend you try a different browser.
    Punch
