Ricko Hasche
Ricko Hasche
- Ricko Hasche
- 4,086
- Member
- 8,039
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 20
Shablov village on ravenloft mood
Community Atlas 1000th map Competition - with Prizes [August/September]
@Monsen I will change to Metzvel on Widow Linn - (same zone).
WIP - back to CSUAC
A1 Inn and Stable Battlemap
Of course, the U-turn in this case of 10x5 is possible, although "complicated" depending on the size of the animal... but they are not there on vacation and where they sleep... it is possibly better than most places where travelers sleep in this world of pain and uncertainty.
But, as I said, this is a (temporary) inn stable and not a farm shed - which in this world would surely belong to a noble or high merchant with enough money to build a very large building.... all this to house only 8 animals maximum = 4 rooms of 10x10 on each side + corridor at least 5 feet wide - recommended would be 40x25 minimum space... I see a lot of GP there that most inhabitants of my world... a dirty and miserable medieval would see this stable (ideal) as a nobleman's mansion by his own standards.
Frozen Wasteland
Castle in a Cloud
Hy @JimP !
I typically use alycia clouds in horizontal orientation in my maps. I always try to vary their size and also, in some cases, use more than one image to make a larger cloud.
Normally i choose placing them to cover free spaces but without disturbing the necessary parts of the map.
After finish the clouds you can put your names with contrast in the glow to stand out over the clouds.
MY MUNDI IS READY!
Sheet Effects stop working consistently
I always start with the mountains when I make my maps. Some styles trees and icons go on the same Sheet = SYMBOLS, in other styles, for example Mike Schley, the trees always go on the SYMBOLS TREES sheet. This initially makes it difficult to "place symbols behind the mountains", so you can create symbols back or symbol trees back to automatically position them behind and give better depth to your drawing.
https://forum.profantasy.com/discussion/12585/working-fast-kinda-tutorial#latest
Hex map
New user from the Netherlands, nice to meet you all!
