Ricko Hasche
Ricko Hasche
Ricko Hasche
4,068
Member
8,027
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
20
  • Oasis
    Cheers
    roflo1MonsenMapjunkieEukalyptusNowLoopysueFersusJimPDaltonSpenceTheschabi[Deleted User]and 10 others.
  • John Roberts Village by night
    LoopysueMonsenroflo1jmabbottRalfMapjunkieJimPWeathermanSwedenLoreleiProchaskaand 7 others.
  • High Lands
    Inspired by a Landscape Photo.
    Names are in Portuguese.
    cheers
    JimPzace66DaltonSpenceGlitch[Deleted User]RaikoLoopysueTheschabiAleDjmabbottand 9 others.
  • Dark Elves Lair
    Mixing Schley and Spectrum Overland style.
    Cheers
    MonsenLautiLoopysueWeathermanSwedenDaltonSpenceKenMScottA[Deleted User]roflo1Lillhansand 12 others.
  • Mixing Mike Schley isometric city + Mike Schley Overland symbols
    31 - create a new sheet and name it TERRAIN Earth (I chose this second name to remind myself that I will use the terrain earth effect on it). Select Terrain Earth
    32 - draw where you want this effect
    33 - refresh and create another new SHEET: TERRAIN DARK GREEN
    34 - draw where you want the dark green
    35 - refresh
    36 - as the program does not allow you to use SYMBOLS TREES by mike schley overland in another SHEET that is not SYMBOLS TREES, we created a new sheet SYMBOLS TREES GRASS. And we place it above (below) symbols and symbols trees.
    37 - Place Scrub 1 and/or 2 where you want (CErtify you are working on Symbols TREES GRASS sheet)
    38 - refresh and you will notice that the "grass" is under the trees and other buildings.
    39 - with the animals previously chosen when importing the schley overland folders, position them on the map
    40 - for a cleaner final file write in the command: COLLARW and hit enter twice
    41 - once clean outside map border, save and your map is ready to go!
    all work, flow, without the stops for print screenings and savings is about 15-20 min max.
    Cheers
    MonsenLoopysueJimPScottAroflo1jmabbottWeathermanSwedenRalfMapjunkieJulianDracosand 6 others.
  • MY MUNDI IS READY!
    After much testing, I didn't like any of the massive tree effects, even though I tested a variety of them... so... I manually put them one by one into a real ZEN state of soul and a machine gun tree with the mouse.
    South West coast of jambolandia.
    Cheers
    MonsenLoopysueQuentenLautiMapjunkieDakMaidhc O CasainjmabbottCalibreEdEand 5 others.
  • Budapest
    For Vampire Dark Age, Legends are in portuguese.
    Mike Schley Overland Style + Cobble land feature from city schley to the floor + Docks from Wielink.
    Cheers
    LoopysueJimPJulianDracosWazzebuWeathermanSwedenMonsenroflo1[Deleted User]EukalyptusNowMapjunkieand 6 others.
  • 2x A0 Battlemap
    I used the Delphi ruins plan as inspiration to my friend campaign,
    Cheers
    MonsenLoreleiJimPLoopysueGeorgeDaltonSpenceMapjunkieRalfTheschabiQuentenand 7 others.
  • Mr. Igor Inn
    Names are in Portuguese,
    Cheers
    JimPMonsenLoopysueroflo1RalfAleDDaltonSpencejmabbottDakGlitchand 7 others.
  • Ukbur Valley
    Cheers
    roflo1MapjunkieLoopysuepablo gonzalezLautiGlitchMonsenMichael RoehrlJimPCalibreand 6 others.
