Ricko Hasche
Ricko Hasche
- Ricko Hasche
- 4,070
- Member
- 8,031
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 20
Oasis
John Roberts Village by night
High Lands
Dark Elves Lair
Mixing Mike Schley isometric city + Mike Schley Overland symbols
31 - create a new sheet and name it TERRAIN Earth (I chose this second name to remind myself that I will use the terrain earth effect on it). Select Terrain Earth
32 - draw where you want this effect
33 - refresh and create another new SHEET: TERRAIN DARK GREEN
34 - draw where you want the dark green
35 - refresh
36 - as the program does not allow you to use SYMBOLS TREES by mike schley overland in another SHEET that is not SYMBOLS TREES, we created a new sheet SYMBOLS TREES GRASS. And we place it above (below) symbols and symbols trees.
37 - Place Scrub 1 and/or 2 where you want (CErtify you are working on Symbols TREES GRASS sheet)
38 - refresh and you will notice that the "grass" is under the trees and other buildings.
39 - with the animals previously chosen when importing the schley overland folders, position them on the map
40 - for a cleaner final file write in the command: COLLARW and hit enter twice
41 - once clean outside map border, save and your map is ready to go!
all work, flow, without the stops for print screenings and savings is about 15-20 min max.
Cheers
MY MUNDI IS READY!
Budapest
2x A0 Battlemap
Mr. Igor Inn
Ukbur Valley
