Ricko
Ricko
- Ricko
- 6,740
- Member
- 10,565
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 22
Reactions
Mini city with overland tutorial
working fast - kinda tutorial
14 - Because they are on the SYMBOLS sheet, once I refresh the drawing, they are automatically behind the trees (SYMBOLS TREES), in case you want the same effect behind, you will have to create a SHEET SYMBOLS hills/dune back and place it below from Symbols BACK and above Symbols trees back. That way they will also automatically go to the right place, under the trees behind.
Community Atlas - Serkbergen / Peredur
How to add a lake ?
9 you can make a lake using hills or mountains too. previously draw your lake with hills or mountains, place some trees on top (or not).
In the fourth photo, highlighted in red, you can notice the lake edges hard as in the first example (also because Sheet Sea II has no effects yet). This time, if you don't want to add effects, you can simply hide those parts using new tree groups. and the final result will be that of the last image.
Cheers
Community Atlas - Berenur - Urtrah Desert
Community Atlas - Arthenn / Berenur
