Ricko
Ricko
- Ricko
- 6,740
- Member
- 10,565
- February 7, 1977
- merlo san luis argentina
- Mapmaker
- 22
Reactions
MY MUNDI IS READY!
Castle in a Cloud
Hy @Royal Scribe !
I was looking at your post and was intrigued by the challenge. I had never thought too about creating a castle in the clouds before. So while watching a boxing match I made this small "Close up" image (size 40x50 - metric). I only used images from Mike Schley style and attach the FCW file in case you want to take a look.
Cheers
WIP - Largo the Cursed Village
Community Atlas - Seven Maps from Seven Maps of the Day
This time, randomness led me to the cold region of Uppsala. I chose to bring to life the small and resilient village of Nora.
Lost Throne A3 55x80 Battlemap
Community Atlas - Fonlorn Archipelago - Bleakness - Death Forest.
On leprechauns and rainbows and pots of gold
Hey @Royal Scribe Beautiful work! Note that in the first image, the waterfall is not in the foreground.
In the second drawing, very beautiful by the way, you can improve it even further by using the trees or other symbols to "hide" the junctions of image with screen, or image with image. Note the points below.
Also, if you want to show an apparent "use" of the magic circle of stones, you can leave it without grass and create a special sheet, above all, to use a hill background or mountain background and give the appearance of a ground "trampled".
Congratulations!
San Luis province - Argentina
Community Atlas - Berenur - Urtrah Desert
Tutorial - Between hills, rivers and trees
In response to the request, I decided to copy and paste here - as well as add more information, the recent conversation I had with Master Quenten, with the intention of sharing the idea, who knows, it might be useful to someone.
This tutorial is about a way to compose the landscape and help with the depth of the map. I only use images from Mike Schley Overland, but it can be used in any style.
The two images above are made up of 3 hills on the left in a zig zag pattern and three hills in a group on the right, in the shape of a horseshoe.
below I chose the exact same two hills as a group. the left "turned" to the left and the right I clicked mirror to invert the image and place it on the right. Note how this simple inversion of the image also inverts the perspective of the drawing. If my maps go "to the left", I try to invert the images so that they go in the same desired direction... it takes a little more work but I notice a big aesthetic difference.
