Ricko
Ricko
Ricko
6,740
Member
10,565
Birthday
February 7, 1977
merlo san luis argentina
Mapmaker
22
  • De Rust + Alyssa Faden clouds
    Health and Progress for all!
    Royal ScribeLoopysueWeathermanSwedenMonsenQuentenRalfEdEJuanpiProchaska
  • City without name
    Cheers
    LoopysueMonsen[Deleted User]roflo1RalfDaltonSpenceAleDLautipablo gonzalezadelia hernandezand 1 other.
  • Aokigahara - the valley of the dead
    cheers
    LoopysueMonsenroflo1[Deleted User]MapjunkieLizzy_MaracujaGlitchBidmaronDaltonSpenceLautiand 2 others.
  • MY MUNDI IS READY!
    A smaller map of the main areas of the Kingdom of Serenia and the West Coast.
    I have the habit of saving the map step by step to compare where something is needed or missing. I usually delete everything after the map is ready. I decided to upload the photos this time, for those who are interested, so that they can compare the expansion of the forest and the addition of effects with its production process.
    The last photo has the colors retouched in Lightroom.
    Cheers
    Royal ScribeLoopysueMonsenBwenGunJuanpiGlitchRalfDak
    New overland map 1000 x 1410 km of the Karkaroff region, this time adapted to the new scales of the world made by @Maidhc O Casain .
    Cheers
    Royal ScribeLoopysueQuentenMonsenGlitchroflo1JuanpiDakRaikoCalibre
    Cheers
    LoopysueRoyal ScribeMonsenroflo1QuentenRalfGlitchJimPJuanpiRaiko
  • Mixing Mike Schley isometric city + Mike Schley Overland symbols
    21 - Here again use the trees to hide details, like the street - in this case leading nowhere, from the structure icons.
    22 - the river is too big to grow the mike schley overland bridge icon which would cause it to pixelate a lot. so I choose the isometric city bridge and place it where I want it.
    23 - after the bridge has been placed i select stone road size 2 and draw on both sides. Always try to get right out of the middle of each part of the bridge your road, so it will be correctly positioned in connection with the bridge.
    24 - now using a dirt road, I place it where the dirt roads will be.
    25 - we already have the trees, buildings, roads and streets. now let's do some decorating. Using isometric images, I position the market, boats, and a few more trees.
    26 - time to place the plantations. You can intersperse the colors or put them all the same, it depends on your taste or need.
    27 - I chose to put both in this example
    28 - Refresh and look how is going
    29 - I want a little more inner edge fade on the roads, so I go to your sheet and increase the intensity of the effect until I get what I want.
    edge fade inner more strong on roads now.
    Refresh and see, maybe adjust settings onde more, untill you like the results.
    30 - let's add green, terrain light green where you want it. I always use these effects beyond the edge of the drawing, since when I use the edge fade inner effect "inside", it doesn't attack the inner edge "in the border".
    refreshed
    MonsenLoopysueJimPScottAjmabbottMapjunkieEukalyptusNowJuanpi
    Hey @Glitch , here another cursed village. This is for my campaign.
    All made in mike schley overland + some symbols from Isometric.
    Cheers
    Royal Scriberoflo1QuentenLoopysueMonsenGlitchRalfJimPCalibreJuanpi
  • Help with sheet effects (blend, I think?)
    hello @Rainshine
    Using this style (mike Schley overland) here its my process:
    1 I position my volcano on the map using the sheet Symbol
    2 I create the sheet SYMBOLS TREES BACK (as <<< to draw attention) and position it above (below) the Sheet symbols and below (above) the sheet symbols back.
    3 select the tree you want and select the new sheet - SYMBOLS TREES BACK
    4 place any tree icon where you want
    5 - refresh
    Tree images on this sheet automatically go behind images on the SYMBOLS sheet. Note the error in the lower left corner where the trunk of the palm tree appears undesirably behind the volcano image.
    Then you can select the icon and delete it (more work) or hide it in the next step.
    6 - Now go back to the original sheet of the SYMBOLS TREES program and work from there.
    This is where I usually "hide imperfections" in images that were poorly placed on the sheet at the back. In this case I cover the root of the palm tree with more palm trees, but it could be a hill, a city, etc.
    7 - If you want to add a "pasture" effect you can still create a SYMBOLS TREES GRASS sheet and place it under all symbols sheets
    8 - select the Scrub vegetation and make sure you are working on the new sheet symbols trees grass (sometimes the program "forces" you to go to another sheet and you have to select the sheet you want again).
    And place the Scrub where you want the effect.
    9 - refresh
    Cheers
    Loopysueroflo1MonsenJimPMapjunkieRainshineGlitchRalfCalibre
