Royal Scribe
Royal Scribe
- Royal Scribe
- 8,804
- Member
- 3,198
- February 5, 1968
- San Francisco, California
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
[Atlas Submission] - Doriant - Gold Coast - Eknapata Desert - Per-Nezahd
Hi @Monsen!
(I believe you said you're going on holiday soon, so if you've already left, this will be waiting for you when you return.)
I found another map that I forgot to submit for the Atlas. I designed it for the last competition but decided it was too large to qualify as a village, so I did a different desert village instead.
Per-Nezahd is located in the Eknapata Desert, on the Gold Coast region of Doriant. I've marked it with a yellow box on this map below:
And here's the map and FCW file. This one also does not have toggles. It doesn't have a map description, either. I can write one if you'd prefer that I include one.
[Atlas Submission] - Doriant - Gold Coast - Eknapata Desert - Kukaar
Most of my Atlas submissions are organized in folders and subfolders named after the Atlas' geography, so it's easy enough for me to poke through to see what's missing. (I did find one more, but I'm debating whether or not to tweak it before formally submitting it.) There are a handful, though, that were designed before I designed the Gold Coast region, and even though I created spots for them in the Gold Coast, I discovered that some were never submitted. Still going through tracking them down (while working on one of my new cities). And others don't have a proper spot as yet, but maybe if I rename them, they will soon have a home. I love the idea of Game Masters using my maps, and would love to hear about the adventures they were used in.
Live Mapping: OSR Dungeons
Seeking: Feather, scale fills
Aww, thank you, @Wyvern!
[WIP] - Doriant - Gold Coast - Eknapata Desert - Sakherma Ruins
The dark brown is a mountain hillside that the caverns are cut into. That hill can be hidden or revealed with a layer. I forgot to post an image showing the mountain revealed but I will do that tomorrow.
The darker gray is meant to show elevation changes going down but they are more pronounced than I was expecting. They are Solid 10 transparencies but when I added a transparency effect, they turned almost black. Maybe I will try as solid black and then add a transparency effect where I will have more control over it darkening.
I removed Remy's tag and changed the header to "WIP," as this isn't quite ready for submission. I will start a new thread when it is.
@Don Anderson Jr., I'm not 100% sure I was following what you were referring to with the "darkened section." If you meant the brown walls, then yes, that was meant to be the caves beneath the mountain. Here's what it looks like with the mountain in place. Everything on this map is meant to be roughly at the same level, with those caves going vertically into the mountain.
But if by "darker" you meant the shaded areas like the spots circled on the map, that was meant to reflect elevation changes descending into lower areas. I may have to do something to make that more subtle.
Working on the dunes, too. I wanted sharpish ridge lines like the dunes of the Sahara Desert, rather than more slopy hills like dunes at a beach, but I still need to extend it a bit so there aren't flat parts on top, and maybe soften the ridge lines a little if a can.
Hi Monsen,
At your convenience, I have a pair of maps to submit. This is for the Sakherma Ruins, which is located in Doriant - Gold Coast - Eknapata Desert in the area boxed here:
I will post the FCW files as follow-ups in this thread.
Also, fellow mappers: I have plans to map the big city of Khemtufu and the Temple of Fah, but feel free to dive in anywhere else in the Eknapata Desert if you wish.
No hate from me! I'm getting better with the mechanics of CC3+ but I'm constantly learning new things. And there are lots and lots of people with a better artistic eye than I have who give me great feedback. Even newbies who may not know how to do a particular thing in CC3 can point out things that just don't look right, or might be confusing. Just like with writing, an outside eye is always helpful because the writer or artist may be too close to the work to notice what might be unclear or confusing to the audience.
