Royal Scribe
Royal Scribe
- Royal Scribe
- 9,537
- Member
- 3,353
- February 5, 1968
- San Francisco, California
- Website
- Real Name
- Kevin
- Mapmaker
- 16
Reactions
Birdseye Continental - style development thread
CC4 Overland Development Thread
Jim Pierce 1947 - 2024
Invasion of the Pod People
Wanted to try out the new Mike Schley cartouche/decorative border symbols, and decided to tweak an existing map rather than create a new one. Really love the new compass rose options.
While I was in there, I deleted the jungle fill in the southwest corner as well as the northwestern edge of the northern island, and replaced them with individual jungle trees.
Creating a Raster Set dimensions.
ALPHA BLUR question
Makes sense. It occurs to me that I would probably want to keep them as separate cutout tools anyway. Sometimes I would want to cut through the wall to the sill, and sometimes wall to floor, and sometimes sill to floor, so that would be a lot of tools to create. Simpler to have one wall-to-sill tool and another sill-to-floor tool (unless I figure out effects that prevent the transparency acne without needing a mask, so I then I can just have wall-to-sill and wall+sill-to-floor tools).
EDIT: Shortly after I started reading the link Joe gave above, I realised that the names of things also vary between two countries that share a common language. What I know in the UK as a watershed is known as a divide in the US.
Hence the old expression, "The British and the Americans are two great peoples divided by a common tongue."
Corrupted Template
[WIP] The Old San Francisco Mint (Dracula Dossier)
Ahhh, ok. Not sure when I will get to creating the library layout, but if you're interested, I can email you the photographs of the blueprints from a book the librarian allowed me to photograph. They are in the public domain now in part because of their age but mainly because they're government documents (in the U.S., all government documents are public domain, though classified docs can still be restricted).
Top down campfire?
Yeah, I agree. The last map where I needed a campfire was designed in Marine Dungeons. I found that in order to keep with the style of Marine Dungeons, it was easier to make my own campfire using the dry rocks from Marine Dungeons and the fire, scorched earth, and burnt wood from Darklands City -- both designed by Sue in complimentary styles. I have a tendency to mix and match from styles that don't always work well together, so sometimes I have to make an effort to rein myself in. Having the scorched earth fill available was handy, but another option would be to use a dark gray earth and then use sheet effects to darken it (or if a gray earth isn't available, use the RGB Matrix set to grayscale on a brown earth fill, and then darken it).
